BT.com
Wishlist
Peerless-AV Arakno Heavy Duty Geared Projector Mount up to 45kg
Delivery
Standard Due date unavailable
The Arakno Geared Projector Mount is designed with superior grip adjustment knobs to deliver the easiest fine-tuning for precise image alignment. Compatible with virtually any projector weighing up to 50 lb it is the easiest, most installer friendly-mount for any application. The ultimate solution for convenient and secure projector installation for ceiling applications.
Peerless Arakno Geared Projector Mount PAG-UNV - mounting kit
Mounting kit - ceiling mountable
Mounting Components
Ceiling plate, adapter plate
Adjustable Width
21.6-44.8 cm
Adjustable Depth
11.4-18.1 cm
Adjustable Height
21.6-44.8 cm
1.4 kg
North America
Recommended Use
Projector
Max Load Weight
22 kg
5 years warranty
Adjustable Width
21.6-44.8 cm
Adjustable Depth
11.4-18.1 cm
Adjustable Height
21.6-44.8 cm
1.4 kg
North America
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Projector
Placing / Mounting
Ceiling mountable
Max Load Weight
22 kg
Quick release, scratch-resistant
Limited warranty - 5 years
Scroll to top
