BT.com
Wishlist
Peerless-AV 6'-8' Adjustable Extension Column for Multi-Display Units
Peerless-AV 6'-8' Adjustable...
£97.66
£97.66
Add to wishlist
Delivery
Standard Due date unavailable
The Adjustable Extension Column features a tube-in-tube design notched and threaded 1 1/2- 11.5 NPT at the lower end. The upper end has a pin fitting for attachment to a compatible Peerless ceiling fixture.
Peerless ADD 0608 - mounting component
Mounting component
Mounting Components
Extension column
Adjustable Height
180-240 cm
9 kg
Adjustable Height
180-240 cm
9 kg
AV Furniture
Mounting component
Mounting Components
Extension column
Adjustable height, bolt fixing
Scroll to top
