BT.com
Wishlist
Peerless-AV 2x2 Video Wall Stand
Delivery
Standard Due date unavailable
Creating a 2 x 2 video wall is simple and cost effective with the Peerless-AV DS-VWS546-2X2 Floor Stand Video Wall Mount. The single frame design easily clamps to the stand uprights making it ideal for Rental and Staging applications. The universal adaptors accommodate displays measuring 40"-46" and place displays on the same vertical plane. Once the displays are mounted, the built in horizontal adjustment leaves a seamless appearance.
Peerless Floor Stand Video Wall Mount DS-VWS546-2X2 - stand
Stand - floor-standing
181.7 cm x 91.4 cm x 183.7 cm
Recommended Use
4 LCD displays
Recommended Display Size
40"-46"
Flat Panel Mount Interface
200 x 200 mm, up to 800 x 400 mm
Max Load Weight
272 kg
Black powder coat
5 years warranty
181.7 cm
91.4 cm
183.7 cm
Black powder coat
AV Furniture
Stand
Recommended Use
4 LCD displays
Placing / Mounting
Floor-standing
Cable Management
Integrated cable management
40"-46"
Max Load Weight
272 kg
Adjustable height
Limited warranty - 5 years
Scroll to top
