BT.com
Wishlist
Peerless-AV 1m 50mm Diameter Extension Pole
Peerless-AV 1m 50mm Diameter...
£23.68
2 in stock
£23.68
Add to wishlist
Delivery
Standard 3-5 working days
The Peerless-AV modular mounts line features a full range of products that can fulfill multiple requirements from a limited number of SKUs. With the universality of the components, configure your own perfect custom flat-panel display or projector mounting solution for any application.
The modular mount line was developed with the professional AV installer in mind. Designed around a 2" diameter pole, the line is ideal for projects as well as for upgrading existing installations.
The MOD-P100-B extension pole is designed for use with the Peerless-AV modular series mounts. They offer perfect solution for tailoring each unique installation with custom cut-to-length poles.
Peerless Extension Poles MOD-P100-B - mounting component
Mounting component
Mounting Components
Extension pole
50 cm 1 m
50 cm
1 m
AV Furniture
Mounting component
Mounting Components
Extension pole
Scroll to top
