BT.com
Wishlist
PCTV Systems Broadway – Wireless TV Streamer for Freeview, Satellite and Cable boxes
PCTV Systems Broadway – Wireless TV...
£72.62
£72.62
Add to wishlist
Delivery
Standard Due date unavailable
WATCH LIVE TV ON YOUR IPAD, IPHONE OR OTHER MOBILE DEVICE.
WITH BROADWAY, YOU HAVE YOUR TV, YOUR WAY!
Watch live TV on your iPad, iPhone, Android phone or tablet plus a PC or Mac. Watch live TV in the home or when you travel!
Introducing Broadway 2T -the simple way to watch live TV on your iPad.
Experience the ultimate in entertainment and never miss your favourite Sports events, TV soaps or live News as it unfolds in front of you anywhere in the world.
Broadway is not only incredibly intelligent, it's also one of the easiest to install dedicated personal video device that brings Live Freeview or Satellite TV to your iPad, iPhone or Android tablets with Google's new Android Honeycomb.
Broadway makes it easy for you to watch live TV on your iPad screen, in your home through Wi-Fi or via the Internet when you travel. Broadway not only works with the iPad but also works with the iPhone, Android phones or tablets, plus Windows PCs or the Apple Mac!
When you're at home, Broadway sends the live TV signal to your iPad (or other supported devices) via your home Wi-Fi network. When you travel, Broadway sends the live TV signal via a 3G connection or, if you're in a place which has Wi-Fi service, via the local Wi-Fi connection.
Watch your favourite TV programs while you're in the garden, sitting in the kitchen or anyplace in your home where you have a Wi-Fi connection
LATEST TECHNOLOGY
With Broadway, brought to you by the brilliant engineers at PCTV Systems, you have Your TV, Your Way!
Inside Broadway are two Freeview TV Tuners whilst on the back are video connections to plug in your satellite or cable digital set top box too. Cleverly, the Broadway box streams two video signals at the same time which means you could be watching one TV, Satellite or Cable channel on your PC whilst another family member could be watching another Freeview TV programme on a mobile device like an iPhone or iPad.
Having Broadway at home means never having to miss your favourite TV shows, sports events or programmes series again!
WATCH SATELLITE TV ON YOUR IPAD TOO. ANY WHERE, ANY TIME!
Broadway includes an audio/video input with S-Video or Composite connectors. Connect your satellite set top box to Broadway via the audio/video inputs and watch satellite TV on your iPad anywhere in the world. Broadway comes with an Infra-Red (IR) Blaster which can remotely change your channels on your Freeview or Sky satellite TV box directly from your mobile device. With one touch of the iPad screen, commands are sent to Broadway telling it to use the IR Blaster to change the channel on your satellite TV box. From anywhere in the world, you can watch your best TV programs on any satellite channel!
Broadway can use its IR Blaster with cable TV boxes too. You can also connect an analogue video camera or webcam and turn Broadway into a video surveillance solution too, viewable Live from your mobile device.
Touch Navigation
Changing channels is quick and intuitive. Control what you want to watch with a touch of your finger on the iPad screen.
Broadway has connections for a TV aerial, plus a satellite or cable TV box.
Setup of Broadway is easy. Connect Broadway to your TV aerial or set top box and connect it to your home router using the network cable provided. Then turn on your iPad, iPhone, MAC or PC and enter http://distan.tv into your browser. Scan for channels and then start watching live TV! It's that simple.
To watch your TV when you're travelling outside the home, just configure your home router to allow remote access to Broadway. Not sure how to do this? Visit www.portforward.com where you get a step by step guide to walk you through it. Alternatively you can call our Broadway support team in the UK and we'll guide you through it free of charge.
If your TV aerial or set top box is not near your router, don't worry. After the initial setup, Broadway will wirelessly connect to your router. Simply move the Broadway to your TV aerial or set top box, enable Broadway's wireless connection to your router, and you're all set!
HOW DOES BROADWAY WORK?
The Broadway 2T is a Digital TV receiver with with two built-in Freeview DVB-T TV tuners, a high quality H.264 video compressor and a 802.11 wireless LAN controller. The powerful built-in H.264 video compressor is used to convert your Freeview digital TV signal, or video from your satellite receiver, into a format which can be viewed on an Apple iPad or iPhone anywhere in the world. The H.264 video compressor can also create a video format which viewed on an Android phone or tablet, or PC or Mac.
High Definition quality and longer battery life on your mobile device
Broadway supports H.264 video compression which enables the highest quality video streaming and also allows the maximum battery usage from your Apple device. Broadway has built-in high performance hardware which converts Freeview digital TV or satellite TV into a format which can be watched on a Apple iPad or iPhone, plus a format which can be watched on Android devices, PCs or Macs.
Broadway is a stand-alone, low power, device. All the settings and set-up can be done through your Internet browser on any Apple or Android mobile device.
WHAT'S IN THE BOX
Broadway 2T dual DVB-T receiver
Power supply
DVB-T antenna
Ethernet network cable
CD-ROM with TVCentre 6 software for Windows
IR learning Blaster cable to control the channel changing on a satellite or cable TV set top box
User manual and quick start guide
PCTV Broadway 2T - digital TV tuner - 802.11n
Digital TV tuner - DVB-T
Interface Type
802.11n
Digital Video Format
MPEG-2, MPEG-4, H.264
Microsoft Windows Vista / XP / 7
Apple iPad 1; 2; iPhone 3G, 3GS, 4; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Interface Type
802.11n
Video
1 x antenna - rear , 1 x network - RJ-45 - rear , 1 x video - S-video input - 4 PIN mini-DIN - rear , 1 x audio / video - RCA phono x 3 - rear
TV aerial, power adapter
1 x network cable - external
Software Included
PCTV TVCenter 6
System Requirements Details
- 1.5 GHz - RAM 1 GB - HD 1 GB
Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4 , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* In Portugal watching Formula 1
Reviewed by Anonymous on 17/03/2015
BBC one have my favorite coverage of formula one, and where I stay on my holiday we don't have access to english speaking coverage, this solves that problem. Set it up at home in the UK, tune it in, all pretty simple and then on my laptop go to the webpage they give you (all done in the setup).
Perfect, I get the DC's coverage and i'm happy!
5* So useful! Watch my TV anywhere I want
Reviewed by Liane on 04/03/2015
Such a cool product. I can stream all my TV channels to my iPhone, iPad or my PC anywhere.
My parents have one at their house. They use it to watch the soaps and all the UK channels when they are at their holiday home in Spain. They can stream live tv remotely while they are there in the villa.
Love it #muchlove
3* Broadway 2T Streamer
Reviewed by Chris on 21/12/2011
Potentially a great device. Small, low powered, can receive freeview TV and broadcast it over the LAN/Wifi (or beyond) enabling portable PCs/ Android/Iphones to watch any TV channel (well two streams can be viewed at once).
Trouble is it is too hard work. Was able connect and configure using PC browser - a good start. However couldn't get it to work on Android. In the end I discovered that changing the browser 'Enable Plug In' settings from the default of 'on demand' to 'always on' fixed it. Now works pretty well, it's a fiddle to select a channel on the small display but once selected can toggle full screen mode.
To record TV you need the PC software TVCenter. However I still can't get this to work. It can find the hardware but wont find any channels, even though I have applied the hotfix.
I tried UK help line but it just played a message saying 'service no longer available'. I haven't received anything constructive via email.
Will post update and increase rating if I fix it
Scroll to top
