BT.com
Wishlist
PCTV systems AndroiDTV Windows and Android Tablet DVB-T Tuner
Turns your Android or Windows Tablet into a TV!
Delivery
Standard Due date unavailable
AndroiDTV (model: 78e) is a revolutionary pluggable TV Tuner which turns your Android handheld or Windows PC into a full-featured TV and PVR.
There is no Wi-Fi or 3G/4G connection needed- no connection charges apply.
The ultra compact DVB-T receiver connects directly to the microUSB port of your Android device. With the included USB cable you can connect it also to your Windows PC.
The user-friendly TVCenter for Android software makes it easy to watch and record live-TV.
AndroiDTV is small enough to fit in your pocket yet powerful enough to give you the freedom to watch on your Android handheld what you want, where you want.
Watch and record TV anywhere without any extra costs and without using up your data plan
Automatic channel scan for DVB-T channels
Extremly small and light receiver
Latest System-on-a-Chip technology with minimum power consumption for longer battery life
Supports Android "Ice Cream Sandwich" or newer
No extra power suppy or battery requiered
TVCenter software (Android)
TVCenter for Android turns your Android device in a mobile DVB-T TV
TVCenter for Android also included an electronic program guide (EPG) - never miss your favourite show!
Watch and record to your hard drive - without any quality loss
Just plug the PCTV AndroiDTV dongle to your device, install the software and watch live TV wherever you want
TVCenter software (Windows PC)
Watch TV in full-screen or a freely scalable window - with a completely new user interface
Use time shift to stop and rewind live TV
Optimized software to run smoothly even on netbooks
Integrated EPG and ultra-fast Teletext (where available)
Technical Specifications
TV standard: Digital terrestrial DVB-T (MPEG-2 (SD&HD), MPEG-4 AVC / H.264(SD))
Tuning range 177,5-226,5 MHz (VHF); 474-858 MHz (UHF)
Channel bandwidth 6, 7, 8 MHz
Interface: USB 2.0 (Hi-Speed)
System Requirements Android
Compatible devices
HTC One X
Nexus 7
Nexus 10
Samsung Galaxy Nexus
Samsung Galaxy Note
Samsung Galaxy Note II
Samsung Galaxy S II
Samsung Galaxy S III
Samsung Galaxy Tab 2
TV Center for Android requires an Android device with minimum 1 Ghz dual-core-processor, Neon support (for example NVIDIA Tegra 3), USB-Host functionality, as well as Android 4.0.3 ("Ice Cream Sandwich") or newer.
System Requirements Windows PC
Microsoft Windows 8, Windows 7 or Windows Vista with latest Service Pack and 512MB RAM (1GB recommended)
or Windows XP (32 bits) with latest Service Pack and 256 MB RAM (512 MB recommended)
PC with 1,5 GHz
Free USB 2.0 port
Internet connection for TVCenter download
Package Contents
AndroiDTV MicroUSB DVB-T Tuner
Mini telescopic antenna
Additional rod antenna
Antenna adapter
USB adapter
Quick start guide
PCTV AndroiDTV 78e - digital TV tuner - USB 2.0
Digital TV tuner - DVB-T
Interface Type
USB 2.0
3.14 cm x 2.2 cm x 0.9 cm
9 g
Digital Video Format
MPEG-2, MPEG-4, DVB, H.264
Electronic Program Guide (EPG), snapshot function
Microsoft Windows Vista / XP / 7 / 8, Android 4.0.3 or later
Interface Type
USB 2.0
3.14 cm
2.2 cm
0.9 cm
9 g
Video
1 x USB 2.0 - 5 pin Micro-USB Type B
Antenna, mini telescopic aerial
1 x aerial adapter - external , 1 x USB adapter - external
Software Included
PCTV TVCenter
System Requirements Details
Android 4.0.3 or later - dual core processor - 1 GHz , Windows Vista/7/8 - 1.5 GHz - RAM 512 MB , Windows XP - 1.5 GHz - RAM 256 MB
Scroll to top
