BT.com
Wishlist
Patriot Memory Fuel Active Mobile Rechargeable Battery 2000mAh Purple
Delivery
Standard Due date unavailable
FUEL Active is the perfect go anywhere mobile rechargeable battery designed for outdoor enthusiast. Built in a high impact, element-resistant housing; FUEL Active provides a powerful battery and LED flashlight to keep devices powered up while camping, hiking, boating or just on-the-go in the city.
Perfect for devices including smartphones, cameras, and GPS units; FUEL Active has built in protection against overcharge, under discharge, over-current, over temperature protection, and short circuit protection to keep these devices protected while in use. FUEL Active also features power pass through technology enabling the battery to be charged when plugged in to a USB or wall outlet, while charging devices.
Patriot FUEL Active power bank - Li-Ion
Power bank
2.13 cm x 10.74 cm x 2.13 cm
72 g
Output Connector Type
USB (power only) - on cable: Micro-USB
5 V
Voltage Provided
5 V
Lithium Ion 2000 mAh
1 year warranty
Power bank
2.13 cm
10.74 cm
2.13 cm
72 g
Enclosure Colour
Purple
5 V
Input Connectors
5 pin Micro-USB Type B (power only)
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A (power only)
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
1 A
Short circuit protection, overcharging protection, overheat protection, over-current protection, built-in flashlight, overdischarging protection
Lithium Ion
2000 mAh
Charged
Micro-USB to USB cable
FCC, RoHS
Limited warranty - 1 year
Scroll to top
