BT.com
Wishlist
Patriot Memory 4GB (2x2GB) Division2 G2 Series 1600MHz DDR3
Delivery
Standard Due date unavailable
The Patriot G2 Series, Division 2 Edition DDR3 memory kits are specifically designed for the 2nd Generation Intel Core processors; Intel's 6 Series platform. The G2 Series delivers the high-performance PC gamers demand at price tags that are easy on the wallet. The low-profile Patriot G2 series sport sleek air-craft grade extruded aluminum heat-spreaders for enhanced cooling performance that delivers superior stability during long hours of gaming, and adds a touch of style to your 2nd Generation Intel Core powered system.
Patriot Extreme Performance Enhanced Latency Kit G2 Series Division 2 Edition - DDR3 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9-24 )
Aluminium heat spreader, Intel Extreme Memory Profiles (XMP) , unbuffered
Voltage
1.65 V
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Voltage
1.65 V
Compatible Slots
2 x memory - DIMM 240-pin
RoHS
Scroll to top
