BT.com
Wishlist
Patriot Memory 16GB (2 x 8GB) DDR3 1600MHz Viper 3 Black Mamba DIMM CL9
Delivery
Standard Due date unavailable
Patriot Memory's Viper 3 series memory kits are designed with true performance in mind. Tested and compatible with Intel's DDR3 compatible processors and chipsets, The Viper 3 series provides the best performance and stability for the most demanding computer environments. The Viper 3 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications.
Patriot Extreme Performance Viper 3 Series Black Mamba Edition - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9-24 )
Aluminium heat spreader, dual channel, Intel Extreme Memory Profiles (XMP 1.3) , unbuffered
Voltage
1.5 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.63
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
RoHS
Scroll to top
