BT.com
Wishlist
Panasonic TX-40CX400B 40" 3840x2160 HDMI USB 4K LED Television
Delivery
Standard Due date unavailable
Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. With every film or program, you'll marvel at the deep blacks, bright whites and vivid colors in all their full glory.
Panasonic TX-40CX400B VIERA - 40" 3D LED TV
LED-backlit LCD TV
Diagonal Class
40"
3D
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Motion Enhancement Technology
200 Hz RMR
Video Interface
Component, composite, HDMI, SCART
HDMI Ports Qty
4 ports
LAN
LCD Backlight Technology
LED backlight - direct-lit LED
Image Aspect Ratio
16:9
Internet Streaming Services
Internet Apps (Simple)
USB
3 ports
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
Energy Class
Class A
Power Consumption (On mode)
63 W
Energy Consumption per Year
91 kWh
91.2 cm x 6.5 cm x 53.2 cm
LED-backlit LCD TV
Energy Class
Class A
63 W
91 kWh
Diagonal Class
40"
Series
VIERA
3D
Video Interface
HDMI Ports Qty
4 ports
Modes
Dynamic Picture Mode
Design
Ultra Narrow Bezel Concept
Dimensions
Without stand
91.2 cm
6.5 cm
53.2 cm
Enclosure Colour
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
200 Hz RMR
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Chrome
Flat Panel Mount Interface
TV Tuner
Conditional Access
Common Interface Plus (CI+) slot
Video Features
Teletext
Teletext Memory
1000 pages
Electronic Programme Guide
Digital EPG
Media Player
USB Port
USB Ports Qty
3
Remote Control
Standard remote
Remote Control Model
Panasonic RC48125(RC5)
Audio System
Surround Mode
Network & Internet Multimedia
LAN
DLNA
Connector Type
4 x HDMI input - side , 3 x USB 2.0 , SCART , Digital audio output (optical) , Headphones , Composite video / component video / audio input , Network
Power supply
Nominal Voltage
AC 230V ( 50/60 Hz )
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
Panel without stand - 91.2 cm x 6.5 cm x 53.2 cm , Panel with stand - 91.2 cm x 27.1 cm x 59.3 cm
Scroll to top
