BT.com
Wishlist
Panasonic TH-70LF50ER 70" Full HD 1920x1080 HDMI LED Display
Panasonic TH-70LF50ER 70" Full HD...
£5,251.76
£5,251.76
Add to wishlist
Delivery
Standard Due date unavailable
High 700-cd/m2 brightness and 5,000:1 contrast ensure excellent, eye-catching visibility even in large public spaces. This greatly increases the promotional value for signage use. The fan-less design prevents malfunctions otherwise caused by dust particles brought in by the fan. This enables safe installation in crowded areas.
Panasonic TH-70LF50ER 70" LED display
LED-backlit LCD flat panel display
Diagonal Class
70"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Wall Components Qty
25
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
260 Watt
160.4 cm x 8.9 cm x 93.1 cm
47 kg
260 Watt
Diagonal Class
70"
Commercial Use
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, Eco mode, 1:1 Pixel Mode, Seam Hides Video Mode
25
Dimensions
Without stand
160.4 cm
8.9 cm
93.1 cm
47 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
5000:1
Brightness
700 cd/m²
Total Pixels
2,073,600
Widescreen Modes
Zoom
Viewing Angle
178°
Viewing Angle (Vertical)
178°
Response Time
9 ms
Certified for 24/7 Continuous Operation, Automatic Picture Positioning, Input Search Function, Function Slot 2.0
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Remote Control
Standard remote
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Composite video input , 2 x audio line-in , HDMI input , Component video / RGB input , DVI-D input , VGA input , Audio line-in , DVI-D output , Serial input , Serial output , Network , Audio line-out
2 AA batteries
GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
175 cm
Depth (Shipping)
34.9 cm
Height (Shipping)
104.7 cm
Weight (Shipping)
56 kg
20 - 80% (non-condensing)
Scroll to top
