BT.com
Wishlist
Panasonic TH-65LFE8E 65" 1920 x 1080 LED Large Format Display
Panasonic TH-65LFE8E 65" 1920 x...
£1,835.29
£1,835.29
Add to wishlist
Delivery
Standard Due date unavailable
This display's slim design allows effective space utilization in stores, showrooms and conference rooms. With its extra small depth, it is also not oppressive when mounted on a wall. The bezel with an extra slim design helps viewers concentrate on the screen image. Moreover, the display features built-in speakers, that eliminate the need for external speakers when displaying content with a soundtrack or when holding videoconferences. There is also no need to consider the space for the speakers when setting up the display. The device also features a LAN control function for Internet-based control, which is highly convenient for operating signage for multiple displays. Control is performed from a PC over a LAN network. Finally, the display boasts a host of input terminals. In addition to providing versatile video displays, these terminals enable external control and simple video wall setup.
Panasonic TH-65LFE8E LFE8 - 65" LED display
LED-backlit LCD flat panel display
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
160 Watt
Power Consumption (On mode)
115 W
145.1 cm x 6.2 cm x 82.9 cm
32.6 kg
160 Watt
115 W
Diagonal Class
65"
Commercial Use
Series
LFE8
TV Tuner
No tuner
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode
Timer Functions
Power on delay
Design
Slim Bezel Design
Dimensions
Without stand
145.1 cm
6.2 cm
82.9 cm
32.6 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Image Contrast Ratio
5000:1
Brightness
350 cd/m²
Widescreen Modes
Zoom
Viewing Angle
176 degrees
Viewing Angle (Vertical)
176 degrees
Response Time
6.5 ms
Backlight Life
50,000 hour(s)
Commercial Features
Input Search Function
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1066 x 600, 1400 x 1050
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Driver Details
Main channel speaker: 2 x full-range driver - 1.18 x 3.15"
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
2 x HDMI , DVI-D input , Audio line-in , Audio line-out , VGA input , Network , Serial , USB , Remote control input , Remote control output , Composite video input
2 AAA batteries, clamper
Power cable - 1.8 m
IEC 60950-1, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, IEC 62087 Edition 2, IEC 61000-3-3:2013, EN 55024:2010, EN 55022:2010 Class A
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Width (Shipping)
166.7 cm
Depth (Shipping)
28 cm
Height (Shipping)
105.2 cm
Weight (Shipping)
47 kg
20 - 80% (non-condensing)
Scroll to top
