BT.com
Wishlist
Panasonic TH-65LFB70E 65" 1920 x 1080 DVI HDMI LCD Display
Delivery
Standard Due date unavailable
The TH-65LFB70 is a multi-touch brilliant Full HD touchscreen which absolutely anyone can use! The LFB70 professional Full HD display incorporates intuitive touch screen technology, fully interactive whiteboard functionality, and the very latest in wireless connectivity to allow you and your colleagues to work more closely as a team. This display is loaded with the next-generation technology you need to be more productive, more efficient, and to achieve better quality results.
Panasonic TH-65LFB70E LFB70 - 65" LED display
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
65"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
575/50i, 575/50p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
Wi-Fi, LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
VA
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
215 Watt
151.7 cm x 10.6 cm x 89.2 cm
58 kg
215 Watt
Diagonal Class
65"
Commercial Use
Combined with
Touchscreen
Series
LFB70
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Landscape mode, 1:1 Pixel Mode
Dimensions
Without stand
151.7 cm
10.6 cm
89.2 cm
58 kg
Enclosure Colour
Display
LCD Display Technology
VA
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
6.5 ms
Backlight Life
50,000 hour(s)
Commercial Features
Infrared multitouch technology, Input Search Function
Stands & Mounts
Flat Panel Mount Interface
684 x 300 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 852 x 480, 1152 x 870, 640 x 400, 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050
Media Player
Supported Video Formats
MPEG-4, WMV, AVI, MOV
Supported Pictures Formats
BMP, JPG
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
Wi-Fi, LAN
LAN Protocol
Ethernet
Wi-Fi Protocol
802.11b, 802.11g, 802.11n, 802.11a
Encryption
128-bit WEP, 64-bit WEP, WPA-PSK (TKIP), WPA2, WPA2-PSK (AES)
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
USB - side , USB - side , Composite video input - rear , Component video input - rear , VGA output - rear , VGA input - rear , Serial - rear , DVI-D input - rear , 2 x audio line-in - rear , Speakers output - rear , 2 x HDMI - rear , Network - rear
Software kit, 2 AA batteries, eraser, 2 pen styluses, stylus stand
USB cable - 2 m
GOST, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EN 60065, IEC 60065
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
No signal power off
Width (Shipping)
171.4 cm
Depth (Shipping)
28.2 cm
Height (Shipping)
102.3 cm
Weight (Shipping)
68 kg
20 - 80% (non-condensing)
Scroll to top
