BT.com
Wishlist
Panasonic TH-42LF8W 42" Full HD LCD Large Format Display
Panasonic TH-42LF8W 42" Full HD LCD...
£882.34
£882.34
Add to wishlist
Delivery
Standard 1-3 working days
This stylish design blends in with surrounding spaces and fills the screen with images. The 6.3 mm (0.25") bezel width of the LF8 series is less than half the 16 mm (0.7") bezel width of the LF6 series. And the slim design makes the depth only 57 mm (2.3"). Since the LF8 series blends in with almost any surroundings and the screen is nearly filled with images, this display has a powerful, eye-catching impact.
Performance with 500 cd/m2 of brightness is required for some signage and other professional applications. This allows images to be beautifully displayed even in large, brightly lit spaces, such as train stations and airports.
There is very little change in color, compared with the VA panel, when the screen is viewed at right or left angles, so the images are crisp and clear. This is ideal for providing correct information to places with a lot of people present, such as public spaces and facilities.
Panasonic TH-42LF8W LF8 - 42" LED display
LED-backlit LCD flat panel display
Diagonal Class
42"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1080/24sF
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
IPS
LCD Backlight Technology
LED backlight - edge-lit
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Input lock, button lock, remote control user level
Settings Cloning Capability
Picture Enhancements
Colour Enhancement, Colour Refiner
Speaker System
2 speakers
USB
Remote Control
Standard remote
Voltage
AC 230V (50/60 Hz)
145 Watt
Power Consumption (On mode)
100 W
94.7 cm x 7.2 cm x 54.1 cm
15.3 kg
145 Watt
100 W
Diagonal Class
42"
Commercial Use
Series
LF8
TV Tuner
No tuner
Video Interface
HDMI Ports Qty
2 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Modes
Portrait mode, landscape mode, 1:1 Pixel Mode, Dynamic Picture Mode
Design
Narrow Bezel Design
Dimensions
Without stand
94.7 cm
7.2 cm
54.1 cm
15.3 kg
Enclosure Colour
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p (Full HD)
Image Aspect Ratio
16:9
Coating
Anti-glare
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
50000:1
Brightness
500 cd/m²
Widescreen Modes
Zoom
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
60,000 hour(s)
Commercial Features
Certified for 24/7 Continuous Operation, MPEG Noise Reduction, Input Search Function, Fail Back
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
200 x 200 mm
Video Features
Analogue Video Input Signals
NTSC, PAL, SECAM, NTSC4.43, PAL-M, PAL-N, PAL60
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 832 x 624, 1280 x 768 (WXGA), 1280 x 1024 (SXGA), 1600 x 1200 (UXGA), 1152 x 864, 1280 x 960, 1280 x 720, 852 x 480, 1152 x 870, 1360 x 768, 640 x 400, 1680 x 1050 (WSXGA+), 1920 x 1080, 1440 x 900, 1280 x 800, 1066 x 600, 1400 x 1050, 1600 x 900
Media Player
USB Port
USB Ports Qty
1
Remote Control
Standard remote
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - built-in - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Fast Ethernet
Supported Consumer Electronics Control (CEC)
PJ Link
Connector Type
Serial output , Serial input , Infrared input , Infrared output , VGA input , 2 x audio line-in , Composite video / component video input , Audio line-out , Network , 2 x HDMI input , DVI-D input , DVI-D output , USB 2.0
2 AAA batteries, 3 clampers
IEC 60950-1, EN55024:2010, AS/NZS CISPR22:2009, EN 61000-3-2:2006+A1:2009+A2:2009 Class D, EN 61000-3-3:2013, EN 55022:2010 Class A
Power supply
Nominal Voltage
AC 230V (50/60 Hz)
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Power on delay
Width (Shipping)
112.3 cm
Depth (Shipping)
20.3 cm
Height (Shipping)
74.3 cm
Weight (Shipping)
20 kg
20 - 80% (non-condensing)
Scroll to top
