BT.com
Wishlist
Panasonic TG6812 DECT Phone - Twin
Delivery
Standard Due date unavailable
When the area around the other party is noisy and it is difficult to hear, you can reduce the surrounding noise to make the speaker's voice easier to hear just by pressing the dedicated button.
Simply attach the key finder/key detector to items that you often misplace, and use the handset to find them quickly and easily. You can see roughly how close you are to your lost item on the LCD screen, and both the handset and key finder/key detector beep when being searched for, making them easy to find. You can add up to four key finders/key detectors.
Panasonic KX-TG6812 - cordless phone with caller ID + additional handset
Cordless phone with caller ID + additional handset
Total Number of Wireless Handsets
2
Cordless Phone Standard
DECT\GAP
Speakerphone
Caller ID
Call Services
Caller ID
Display
LCD display - monochrome - Yes
Body Colour
Cordless phone
Additional Handsets Qty
1
2
Body Colour
Phone Features
DECT\GAP
Call Services
Caller ID
Caller ID Type
Caller ID
Max Handsets Supported
6
Multi-Handset Configuration
Phonebook transfer
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
Speakerphone
Menu Operation
Ring Tones
40
Polyphonic Ringer
Handset Locator
Indicators
Visual ringer light
Lighted Keypad
Additional Functions
Alarm, call barring, built-in clock with snooze function, phonebook transfer
Additional Features
Noise reduction, key lock, eco mode, night mode
Phone Memory
Phone Directory Capacity
120 names & numbers
Dialed Calls Memory
10
Caller ID Memory
50 names & numbers
Display
Display Location
Handset
Diagonal Size
1.8"
Display Resolution
103 x 65 pixels
Backlit
Power adapter, phone charging stand
2 x battery - AAA type
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 900 min
Standby Time
Up to 170 h
Recharge Time
7 hour(s)
Dimensions & Weight (Base)
10.7 cm
8.6 cm
7.7 cm
98 g
Dimensions & Weight (Handset)
4.8 cm
2.9 cm
16.4 cm
129 g
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* panasonic dect
Reviewed by P Hollister on 27/03/2016
being asked for a review before I've bought it. I am thinking of buying for a friend as I did buy older but similar model and am happy with it
Scroll to top
