BT.com
Wishlist
Panasonic PT VZ575NAJ WUXGA LCD 4500 Lumens Projector
Panasonic PT VZ575NAJ WUXGA LCD...
£1,812.67
£1,812.67
Add to wishlist
Delivery
Standard Due date unavailable
Panasonic PT-VZ575N are the first portable LCD projectors that feature WUXGA (1920 x 1200 pixel) resolution, bringing native Full HD video to big screens in small spaces. Images are pin-sharp, liquid-smooth, and loaded with detail for an immersive viewing experience.
Panasonic PT-VZ575NAJ - LCD projector - 802.11n wireless / LAN
LCD projector - 1080p
Built-in Devices
Speaker
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Vertical
Bulb type
UHM 270 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), IEEE 802.11n wireless / LAN
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
Speakers
Speaker(s) - integrated
38.9 cm x 33.2 cm x 12.5 cm
4.9 kg
Built-in Devices
Speaker
802.11a/b/g/n, Ethernet
Projector
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.1 - 1.8:1
Uniformity
85 %
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
2,304,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
100 Hz x 91 kHz
Bulb type
UHM 270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Deep Color, Split Screen, PJlink, AMX Device Discovery, Direct Power Off, Crestron e-Control, Colourboard Mode, Dynamic Mode, Digital Link, USB Viewer, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6-2.12
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-25 / +25
Horizontal Keystone Correction
-30 / +30
Vertical
Vertical Lens Shift
44%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11a, IEEE 802.11n, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel - 4 cm
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input / RGB output - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
2 x AAA batteries, wireless remote control, cable holder
1 x VGA cable
Security Features
Password protection, security bar
Power Source
AC
Nominal Voltage
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software
38.9 cm
33.2 cm
12.5 cm
4.9 kg
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
Scroll to top
