BT.com
Wishlist
Panasonic PT FW430EA - LCD projector - 3500 ANSI lumens - WXGA (1280 x 800) - widescreen
Delivery
Standard Due date unavailable
The Panasonic PT-FW430 series boasts high performance with minimal maintenance over time. Its highly reliable optical system and dust-resistant structure provide a long operating life. Advanced Panasonic technologies, such as Daylight View Premium, ensure excellent projected images. The PT-FW430 series model is equipped with many ecology-conscious features, starting with eco management functions that reduce wasteful power consumption. This high-quality projector also supports wireless projection from not only PCs but also iPads and other devices for easy use. Superb installation flexibility, thanks to the 2x zoom lens and horizontal/vertical lens shift, also makes the PT-FW430 series ideal for both first-time installation and as replacement units.
Panasonic PT-FW430EA - LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
3500 lumens
Contrast Ratio
600:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
UHM 250 Watt
Bulb life cycle
Up to 6000 hour(s)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
330 Watt
43 cm x 32.3 cm x 12.6 cm
6 kg
LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
3500 lumens
Contrast Ratio
600:1
Image Size
84 cm - 762 cm
Throw Ratio
1.34 - 2.68:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1680 x 1050 (resized)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
85.1 Hz x 91.1 kHz
Bulb type
UHM 250 Watt
Bulb life cycle
Up to 6000 hour(s)
Eco-Mode technology, Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Side-by-Side, Detail Clarity Processor 3, PJlink, 16:10 aspect ratio support, Direct Power Off
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.6
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Vertical Lens Shift
51% / 51%
Horizontal Lens Shift
24% / 24%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-I input - 24+5 pin combined DVI , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Wireless remote control
ISO 9001, ISO 14001, RoHS
Nominal Voltage
330 Watt
Power Consumption Operational (Standby)
9 Watt
Software Included
Wireless Manager Mobile Edition 5.5, Multi Projector Monitoring & Control Software 2.5, Logo Transfer Software
43 cm
32.3 cm
12.6 cm
6 kg
20 - 80% (non-condensing)
Sound Emission
33 dB
29 dB
Scroll to top
