BT.com
Wishlist
Panasonic PT EX16KE - LCD projector - 16000 ANSI lumens - XGA (1024 x 768) - 4:3
Panasonic PT EX16KE - LCD projector...
£12,373.33
£12,373.33
Add to wishlist
Delivery
Standard Due date unavailable
The PT-EX16KE LCD projector features 16,000 lumens of brightness XGA resolution, is added to the large venue lineup for houses of worship, mid sized rental and staging and customers seeking large venue projection images for moderate use. The product is equipped with a quad lamp technology and encased in a ruggedized shell for high reliability and durability. In addition, its unique light filtering technology recognizes high color purity to deliver vivid images.
Panasonic PT-EX16KE - LCD projector
LCD projector
Asia, Middle East, Africa, Europe, Oceania
Brightness
16000 lumens
Contrast Ratio
2500:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
4 x 380 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 1125/60i, 1125/50i, 1035/60i
Video Output
RGB
AC 230V (50/60 Hz)
1850 Watt
65 cm x 81.5 cm x 34.9 cm
46.5 kg
LCD projector
Projector
Brightness
16000 lumens
Contrast Ratio
2500:1
Image Size
102 cm - 1524 cm
Uniformity
90 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Video Bandwidth
162 MHz
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
85 Hz x 80 kHz
Bulb type
4 x 380 Watt
Bulb life cycle
Edge blending, High-bandwidth Digital Content Protection System (HDCP), carrying handle, PJlink
Lens
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Input Device
External
1 x DVI-D input - 24+1 pin digital DVI , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite / component video / RGB input - BNC x 5 , 1 x USB - 4 pin USB Type B , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232C output - 9 pin D-Sub (DB-9)
Wireless remote control
1 x VGA cable
Security Features
RoHS
Nominal Voltage
AC 230V (50/60 Hz)
1850 Watt
Power Consumption Operational (Standby)
18 Watt
Software Included
Real Color Manager Pro, Logo Transfer Software, Multi Projector Monitoring & Control Software
65 cm
81.5 cm
34.9 cm
46.5 kg
5 °C
20 - 80% (non-condensing)
Sound Emission
51 dB
48 dB
Scroll to top
