BT.com
Wishlist
Panasonic PT DZ570E - DLP Projector - 4000 ANSI lumens - WUXGA (1920 x 1200) - widescreen - 1080p
Delivery
Standard Due date unavailable
In response to the increasing popularity of widescreen image viewing, including Blu-ray content, the PT-DZ570 features native WUXGA resolution for high-definition viewing. This brings you lifelike projection of intricate, highly detailed images.
When the output level of the source device fluctuates due to the performance of the device or its cable connections, the original black and white levels of the image content cannot be reproduced correctly. With the PT-DZ570, you can view the waveforms on the screen and adjust the settings either automatically or manually as you prefer.
The PT-DZ570 series can be easily operated remotely over a LAN, because it is done using the computer's web browser. Furthermore, the projector sends an email message to notify the operator when an error has occurred, or a lamp needs to be replaced.
The PT-DZ570 can simultaneously display images from two sources onto a single screen. For example, you can display a PC image on the left and a video image on the right. Taking advantage of the wide-screen projection, this function gives you a host of new application possibilities to explore.
Panasonic PT-DZ570E - DLP projector
DLP projector - High Definition 1080p
Ethernet, Fast Ethernet
Brightness
4000 lumens
Contrast Ratio
2000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Horizontal, vertical
Bulb type
UHM 300 Watt
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 480i, 576p, 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 1080/25p, 576/50i, 1035/60i
415 Watt
33.2 cm x 48.5 cm x 16.8 cm
8.5 kg
DLP projector - HD 1080p
Ethernet
Projector
Brightness
4000 lumens
Contrast Ratio
2000:1
Image Size
102 cm - 762 cm
Throw Ratio
1.45 - 2.94:1
Uniformity
90 %
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
2,304,000 pixels (1920 x 1200)
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHM 300 Watt
Bulb life cycle
Integrated de-interlacer (progressive scan), Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Side-by-Side, Detail Clarity Processor 3, Waveform Monitor, 3:2 pull down compensation, Deep Color, PJlink, 3D Color Management, digital noise reduction, RGB Booster, Vivid Color Control, DICOM Simulation Mode
Lens
Focus Type
Manual
Lens Aperture
F/2.0-3.4
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Lens Shift Type
Manual
Vertical Lens Shift
60%
Horizontal Lens Shift
10% / 10%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-D input - 24+1 pin digital DVI , 1 x component video / RGB input - BNC x 5 , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - BNC , 1 x S-video input - 4 PIN DIN , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x remote control input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
Wireless remote control
Security Features
Password protection, text superimposing
ISO 9001, ISO 14001
Nominal Voltage
415 Watt
Power Consumption Operational (Standby)
15 Watt
Software Included
Drivers & Utilities, Wireless Manager Mobile Edition 5.5
33.2 cm
48.5 cm
16.8 cm
8.5 kg
45 °C
20 - 80%
Scroll to top
