Click to visit BT.com
BT.com
Wishlist
Panasonic Lumix DMC-FZ200 Bridge Camera 12.1MP 24x Optical Zoom
Quicklinx: 8MLRWS00
Mfr#: DMC-FZ200EBK
Type: Compact
Resolution: 12.1Megapixel
Optical Zoom: 24
Colour: Black
£291.86
Essential accessories
Panasonic Lumix DMC-FZ200 Digital Bridge Camera
The Panasonic DMC-FZ200 is a Bridge camera that has fantastic Leica optical quality and bright f/2.8 aperture right through the 24x zoom range. It also has Full HD video, high speed burst and a pin-sharp electronic viewfinder.
Extra Bright 24x Zoom
The Leica 24x (25-600mm equivalent) zoom lens features f/2.8 maximum aperture throughout the zoom range. This is the world's first zoom of this range on a compact digital camera to have full range f/2.8 maximum. The lens also has Nano Surface Coating as protection against ghosting and flare. If the huge 24x zoom still needs to be extended then there is 48x Intelligent Zoom which uses Intelligent Resolution Technology to enlarge the image with very little falloff in quality.
High Sensitivity and Low Noise
The FZ-200 uses a 12.1 Megapixel High Sensitivity MOS Sensor which has a high Signal-to-Noise ratio and there is further Advanced Noise Reduction using the Venus Engine processor. This uses a combination of Multi-process and Intelligent Noise Reduction methods, the latter separating smooth and edge areas for different levels of noise reduction. What does all this mean for your pictures? These features combined with the bright lens optics allow the FZ200 to carry on shooting quality images in levels of light far below the point where many other cameras fail to produce images at all.
High Speed
The High Speed MOS Sensor is also useful in that its fast operation allows 12fps Burst shooting, using the mechanical shutter at full resolution. There is also a fast 0.95-second startup time and Light Speed Autofocus to make sure you don't miss that all-important shot.
Detailed Viewfinder
In addition to the large 3.0" monitor, this camera is equipped with a 1.312 million-dot 0.20-inch EVF (electronic viewfinder) with 100% field of view. The refresh rate of 60fps makes it possible to easily track fast moving subjects.
Full HD Progressive Video
The DMC-FZ200 records in the highest video quality, Full 1920x1080 50p HD in AVCHD format. There is also a 100fps High Speed HD Video (720p) mode - or 200fps in VGA for dramatic slow motion. For files to transfer to computer and share online there is the option of MP4 recording. Power O.I.S. (Optical Image Stabilisation) with Active Mode makes it possible to film while walking and is also ideal for filming children playing.
Panasonic Lumix DMC-FZ200 - digital camera - Leica
Digital camera - compact
Lens Included
Leica
Memory Card Slot
SD card
Image Processor
Venus Engine
Sensor Resolution
12.1 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 24 x zoom - 4.5 - 108 mm - f/2.8
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Digital Zoom
4 x
Image Stabiliser
Optical (POWER O.I.S. with Active Mode)
Camera Flash
Pop-up flash
Viewfinder
Electronic - 0.21" - colour - electronic
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 1200 mAh ( included )
Interfaces Provided
Composite video/audio, HDMI
12.52 cm x 11.02 cm x 8.66 cm
537 g
Lens Included
Leica
Enclosure Colour
Sensor Resolution
12.1 Megapixel
Optical Sensor Type
MOS
Total Pixels
12,800,000 pixels
Effective Sensor Resolution
12,100,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
24 x
Digital Zoom
4 x
Image Processor
Venus Engine
Image Stabiliser
Face Detection
Surround Sound
Dolby Digital AC-3 (2 channel) recording
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
23
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face Detection AF/AE, Face Recognition
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG, MPO, MPO + JPEG
1920 x 1080
Interfaces Provided
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto, ISO auto (1600-6400)
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Portrait mode, night portrait, PET, scenery, food, 3D image, panorama assist, night scene, panning, sports mode, sunset, glass, high sensitivity, soft skin, baby1, baby2, handheld night shot, Dynamic Range (HDR)
Special Effects
Black & White, Sepia, Vivid, Custom Effect, soft focus, natural, monochrome, portrait, miniature, Cross Process, Retro, Happy, Expressive, high dynamic, Dynamic B&W, High Key, Low Key, Scenery, Toy effect, Star Filter, Impressive Art, One Point Colour
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
60 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
Auto Exposure Bracketing
3 steps
White Balance Bracketing
Lens System
Leica zoom lens - 24 x zoom - 4.5 - 108 mm - f/2.8
Focal Length Equivalent to 35mm Camera
25 - 600mm
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
11 groups / 14 elements
ED glass, aspherical lens, Nano Surface coating
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode, red-eye reduction
AF illuminator
Effective Flash Range
0.3 m - 13.5 m : ISO auto ( wide lens ) , 1 m - 13.5 m : ISO auto ( tele lens )
Additional Features
Continuous Shooting Speed
2 frames per second, 12 frames per second, 5.5 frames per second, 40 frames per second (5MP), 60 frames per second (2.5MP)
Self Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
Built-in speaker, RGB primary colour filter, digital noise reduction, sharpness control, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, cropping an image, resizing an image, saturation control, Intelligent Scene Selector, highlight point display, in-camera film editing, takes photos while film recording, Intelligent Resolution Technology, face detection, Motion Detection Technology, automatic display brightness adjustment, Dolby Digital Stereo Creator, Intelligent D-range Control, Intelligent Auto Plus (iA+), text stamp, high-speed recording, Multi-process Noise Reduction, Light Speed AF, Intelligent Noise Reduction system
Viewfinder
Viewfinder Type
Electronic - electronic
Viewfinder Colour Support
Viewfinder Diagonal Size
0.21"
Viewfinder Resolution
1,312,000 pixels
Optical Viewfinder Field Coverage
100%
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Rotating
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Microphone Features
Zoom, wind noise reduction
Connector Type
1 x USB , 1 x HDMI output , 1 x composite video/audio output , 1 x microphone , 1 x remote control
Software
Software
Adobe Reader, SILKYPIX Developer Studio, Panasonic PHOTOfunSTUDIO 8.3 Premium Edition
Lens hood, battery charger, lens cap, shoulder strap, USB cable, lens cap strap
Details
Battery Life Details
Photo shooting - 540 shots , Video recording - 3.33 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Image Storage
JPEG 4000 x 3000 , JPEG 4000 x 2672 , JPEG 4000 x 2248 , JPEG 3264 x 2448 , JPEG 3264 x 2176 , JPEG 3264 x 1840 , JPEG 2560 x 1920 , JPEG 2560 x 1712 , JPEG 2560 x 1440 , JPEG 2048 x 1536 , JPEG 2048 x 1360 , JPEG 1920 x 1080 , JPEG 1600 x 1200 , JPEG 640 x 480 , JPEG 640 x 424 , JPEG 640 x 360 , JPEG 2992 x 2992 , JPEG 2448 x 2448 , JPEG 1920 x 1920 , JPEG 1536 x 1536 , JPEG 480 x 480
Video Capture
AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , AVCHD - 1280 x 720 - 60 fps - 13Mbps , H.264 - 1920 x 1080 - 30 fps - 20Mbps , H.264 - 1280 x 720 - 30 fps - 10Mbps , H.264 - 640 x 480 - 30 fps - 4Mbps , H.264 - 1280 x 720 - 120 fps , H.264 - 1280 x 720 - 240 fps
12.52 cm
11.02 cm
8.66 cm
537 g
Panasonic Lumix DMC-FZ200 Bridge Camera 12.1MP 24x Optical Zoom Bundle deal on Panasonic Lumix DMC-FZ200 Bridge Camera 12.1MP 24x Optical Zoom
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£301.85
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£295.95
saving £0.88
Type: Compact
Optical Zoom: 24
Colour: Black
Brand: Panasonic
Price Range Inc VAT: 150 - 300
