BT.com
Wishlist
Panasonic KXMB2025EW Multifunctional
Delivery
Standard Due date unavailable
The Panasonic KX-MB2000 Series of compact multi-functional printers are an excellent choice for small offices and remote home offices. They feature a 24-ppm high-speed printer, diverse copy functions, a high-resolution color scanner with up to 9600 dpi (interpolated), and a 33.6 kbps Super G3 Fax. They also come bundled with the Easy Print Utility, which includes a print image control function that simplifies the production of complex documents. The compact KX-MB2000 Series body contains the functions you need for business.
Panasonic KX-MB2025E-W - multifunction printer ( B/W )
Fax / copier / printer / scanner
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser ( monochrome )
Max Copying Speed
Up to 24 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Max Printing Resolution
Up to 600 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Scanning
600 x 1200 dpi
Original Size
A4 (210 x 297 mm), Letter A (216 x 279 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
PC Connection Availability
PC Connection
USB 2.0
42 cm x 43.2 cm x 30.5 cm
12 kg
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
PC Connection
USB 2.0
White
Standard Memory
32 MB
Copying
Max Copying Speed
Up to 24 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
8 on 1, 2 on 1, 4 on 1, Image Repeat
Printing
Up to 600 x 600 dpi
Max Printing Speed
Up to 24 ppm
Printer Drivers / Emulations
Windows GDI driver
Scanning
Optical Resolution
600 x 1200 dpi
Interpolated Resolution
9600 x 9600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Machine Features
One Touch Dialing
6 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Document & Media Handling
Max Original Size
Original Type
Sheets
20 sheets
Max Media Size
Legal
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), B5 (176 x 250 mm), Folio (216 x 330 mm), 216 x 340 mm
250 sheets
1 sheet
Input tray - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) , ADF - 20 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) , Bypass tray - 1 sheet - Legal (216 x 356 mm)
Speed Details
Printing: up to 24 ppm , Copying: up to 24 ppm
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Vista
42 cm
43.2 cm
30.5 cm
12 kg
Accessories
£31.71
Scroll to top
