BT.com
Wishlist
Panasonic KV-SS081 Flatbed Scanner
£528.22
£528.22
Add to wishlist
Delivery
Standard Due date unavailable
This Panasonic scanner features flatbed scanning for scanning passports, datebooks, and other special documents. The scanner is also equipped with a Start button, so work efficiency can be increased by quickly scanning while turning the book's pages, with no PC operation necessary. You can also use its flatbed to scan 2-page spreads from books, magazines, etc., and automatically divide the single image into two sheets. Dividing scanned documents saves time and trouble because it makes complex editing operations unnecessary. Finally, save time by reducing the number of scans with Multi-Crop - place various-sized documents on the flatbed and scan them all at once, then crop whatever parts you need. This is convenient for scanning multiple business cards and thick documents.
Panasonic KV-SS081-U - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 297 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Speed
3 sec / page
Max Document Size
216 mm x 297 mm
Document Feeder Type
Manual
41 cm x 30.9 cm x 5.4 cm
2.5 kg
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Element Type
Scan Speed
3 sec / page
Scanner Speed Details
3 sec/scan - colour - A4 - 300 dpi , 3 sec/scan - black & white - A4 - 300 dpi
Scanner Features
2-Page Separation, Multi-Crop
Media Handling
Max Document Size
216 mm x 297 mm
Manual
USB 2.0
1 x USB cable
Power Consumption Operational (Standby)
8 Watt
Power Consumption Stand by
2 Watt
Power Consumption Sleep
2 Watt
41 cm
30.9 cm
5.4 cm
2.5 kg
10 °C
35 °C
20 - 80%
Other bundles
£528.22
Keep your electronic devices protected
£548.21
Scroll to top
