BT.com
Wishlist
Panasonic KV-S5076H Document Scanner
Panasonic KV-S5076H Document...
£2,724.54
Hurry, only 3 left in stock!
£2,724.54
Add to wishlist
Delivery
Standard 1-3 working days
The KV-S5076H features multiple sensors which detect various types of stapled documents, and to immediately stop the scanner when a staple is detected. Staples are quickly detected in any location, minimizing damage to both the document and the optical glass.
Ultrasonic sensors accurately detect double feeding, even when scanning documents of various thicknesses. When detected, the ultrasonic sensor prevents double-feeding by immediately stopping the scanning process.
Panasonic KV-S5076H - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
307 x 2540 mm
Europe
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
307 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
35000 scans per day
AC 230V (50/60 Hz)
Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP SP3 (32 bit) or later
46.8 cm x 44.4 cm x 34.4 cm
17.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 3.0
307 x 2540 mm
Europe
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
100 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
35000 scans per day
Scanner Speed Details
100 ppm - landscape - A4 , 200 ipm - duplex - landscape - A4 , 97 ppm - landscape - Letter , 194 ipm - duplex - landscape - Letter , 75 ppm - portrait - A4 , 150 ipm - duplex - portrait - A4 , 80 ppm - portrait - Letter , 160 ipm - duplex - portrait - Letter
Scanner Features
Ultrasonic Double Feed Detection, Multi Color Dropout, Double Exposure, De-skewing, Image Emphasis, Gamma Correction, Automatic Separation, Noise Reduction, Shadow Removal, Mirror Image, Automatic Image Orientation, Long Paper Mode, Blank Page Removal, Error Diffusion, Automatic Binary / Color Distinction, blank page skipping, Dither, Auto Crop, Auto Deskew, auto preview, Smooth Background, White Level from Paper, stapled document detection, auto brightness, auto glass cleaning, monochrome reversing, 2-Page Separation, Intelligent Paper Ejection Control
TWAIN, ISIS
Media Handling
Max Document Size
307 mm x 2540 mm
Automatic
300 sheets
USB 3.0
Roller cleaning paper, shading paper
1 x USB cable - 2.4 m
ENERGY STAR Certified
Internal power supply
AC 230V (50/60 Hz)
Power Consumption Operational (Standby)
(1.4 Watt)
Software Included
Drivers & Utilities, Image Capture Plus
46.8 cm
44.4 cm
34.4 cm
17.8 kg
10 °C
35 °C
20 - 80%
Scroll to top
