BT.com
Wishlist
Panasonic KV-S5055C Document Scanner
Panasonic KV-S5055C Document...
£2,557.39
£2,557.39
Add to wishlist
Delivery
Standard 1-3 working days
Boost your business efficiency with an A3-size, high speed document scanner. The fast 90 ppm scan speed and 200-page automatic document feeder of the KV-S5055C make it ideal for both large-volume and distributed scanning environments. Panasonic's unique paper feed mechanism also minimizes the possibility of damaging important documents and ensures precise feeding to make your office work even more efficient.
Panasonic KV-S5055C - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Max Supported Document Size
A3 (297 x 420 mm)
Europe
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
305 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, check
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
AC 230V (50/60 Hz)
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit
46.8 cm x 44.4 cm x 33.9 cm
18 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A3 (297 x 420 mm)
Europe
Scanner
Input Type
Grayscale Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
90 ppm
Duty Cycle
15000 scans per day
Scanner Speed Details
70 ppm - portrait B&W - A4 - 200 dpi , 140 ipm - duplex - portrait B&W - A4 - 200 dpi , 90 ppm - landscape B&W - A4 - 200 dpi , 180 ipm - duplex - landscape B&W - A4 - 200 dpi , 70 ppm - portrait colour - A4 - 200 dpi , 140 ipm - duplex - portrait colour - A4 - 200 dpi , 90 ppm - landscape colour - A4 - 200 dpi , 180 ipm - duplex - landscape colour - A4 - 200 dpi , 50 ppm - portrait B&W - A4 - 300 dpi , 100 ipm - duplex - portrait B&W - A4 - 300 dpi , 60 ppm - landscape B&W - A4 - 300 dpi , 120 ipm - duplex - landscape B&W - A4 - 300 dpi , 50 ppm - portrait colour - A4 - 300 dpi , 100 ipm - duplex - portrait colour - A4 - 300 dpi , 60 ppm - landscape colour - A4 - 300 dpi , 120 ipm - duplex - landscape colour - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, Double Exposure, Blank Page Removal, Automatic Binary / Color Distinction, Auto Crop, Auto Deskew, Smooth Background
TWAIN, ISIS
Media Handling
Max Document Size
305 mm x 2540 mm
Automatic
200 sheets
USB 2.0
Blower, roller cleaning paper, shading paper
1 x USB cable
ENERGY STAR Certified
Internal power supply
AC 230V (50/60 Hz)
Software Included
Drivers & Utilities, Image Capture Plus
46.8 cm
44.4 cm
33.9 cm
18 kg
10 °C
35 °C
20 - 80%
Scroll to top
