BT.com
Wishlist
Panasonic KV-S4065CL Document Scanner
Delivery
Standard Due date unavailable
Offering a stunning array of performance, efficiency and reliability, Panasonic's KV-S4065CL low-volume production scanner is optimized for deployment in organizations with heavy volumes of paperwork. With the ability to scan virtually any type of document, from business cards to legal size paper, the KV-S4065CL is an essential solution for any organization with a steady flow of scanning.
Beyond standard documents, the KV-S4065CL also features the ability to scan continuous documents of up to 100" in length such as EKG reports or well logs. With available ToughFeed technology, it utilizes ultrasonic double-feed sensors and staple detection to safeguard against any disruptions to the scan process.
Featuring a sturdy, dependable construction and a rugged and durable design, the KV-S4065CL fits comfortably into any low-volume scanning environment. Whether it's scanning a single page or a full stack of documents, the KV-S4065CL provides you with an exceptionally powerful and robust scanning solution.
Panasonic KV-S4065CL-U - document scanner
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Hybrid CIS/CCD
Max Supported Document Size
227 x 2540 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
80 ppm (mono) / 80 ppm (colour)
Max Document Size
227 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
30000 scans per day
AC 120/230 V ( 50/60 Hz )
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP 32-bit
47.4 cm x 58.5 cm x 32.9 cm
25 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Interface Type
USB 2.0
227 x 2540 mm
Scanner
Input Type
Grayscale Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Hybrid CIS/CCD
Max Document Scan Speed B/W
80 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
30000 scans per day
Scanner Speed Details
80 ppm - landscape B&W - A4 / Letter - 200 dpi , 160 ipm - duplex - landscape B&W - A4 / Letter - 200 dpi , 80 ppm - landscape B&W - A4 / Letter - 300 dpi , 160 ipm - duplex - landscape B&W - A4 / Letter - 300 dpi , 65 ppm - portrait B&W - Letter - 300 dpi , 60 ppm - portrait B&W - A4 - 300 dpi , 130 ipm - duplex - portrait B&W - Letter - 300 dpi , 120 ipm - duplex - portrait B&W - A4 - 300 dpi , 80 ppm - landscape colour - A4 / Letter - 200 dpi , 80 ppm - landscape colour - A4 / Letter - 300 dpi , 160 ipm - duplex - landscape colour - A4 / Letter - 200 dpi , 160 ipm - duplex - landscape colour - A4 / Letter - 300 dpi , 65 ppm - portrait colour - Letter - 200 dpi , 65 ppm - portrait colour - Letter - 300 dpi , 60 ppm - portrait colour - A4 - 200 dpi , 60 ppm - portrait colour - A4 - 300 dpi , 130 ipm - duplex - portrait colour - Letter - 200 dpi , 130 ipm - duplex - portrait colour - Letter - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 200 dpi , 120 ipm - duplex - portrait colour - A4 - 300 dpi
Scanner Features
Ultrasonic Double Feed Detection, double feed prevention roller system, Multi Color Dropout, Black Page Removal, Double Exposure, De-skewing, Automatic Separation, Noise Reduction, Long Paper Mode, Dynamic Threshold, Blank Page Removal, Error Diffusion, Patch Code Detection, Separation Sheet Detection, Barcode Detection, Intelligent Feed Control, Automatic Binary / Color Distinction, Mixed Document Feeding, Dither, MultiStream Technology, Auto Crop, Auto Deskew, Smooth Background, White Level from Paper, Detect Control, Punch Hole Removal
TWAIN, ISIS
Media Handling
Max Document Size
227 mm x 2540 mm
Plain paper
Automatic
300 sheets
USB 2.0
Blower, roller cleaning paper, shading paper, control sheet
1 x USB cable
External power adapter
Power Consumption Operational (Standby)
( 5.3 Watt )
Software Included
Drivers & Utilities, QuickScan Pro (Demo), RTIV, Image Capture Plus, Multi Color Dropout
47.4 cm
58.5 cm
32.9 cm
25 kg
Limited warranty - replacement - 1 year - shipment
15 °C
30 °C
20 - 80%
Scroll to top
