BT.com
Wishlist
Panasonic KV-S1065C Document Scanner
Panasonic KV-S1065C Document...
£626.37
£626.37
Add to wishlist
Delivery
Standard 1-3 working days
Designed for the modern digital office, the KV-S1065C document scanner is an essential tool for all your document capture needs. This robust and highly reliable workgroup scanner packs plenty of punch, and is the perfect solution for any document capture application.
Boasting a compact footprint, only slightly larger than a sheet of letter size paper, the Panasonic KV-S1065C scanner can hold up to 75 originals with a scan speed up to 60 pages per minute or 120 impressions per minute when duplex scanning is enabled. The Panasonic KV-S1065C is also capable of scanning up to 3 hard plastic cards in a single scan and can handle a variety of paper weights, types, and lengths as well as multipart forms.
Included with every Panasonic KV-S1065C scanner is a copy of Panasonic? s very own Image Capture Plus software. This simple, yet powerful capture software offers an intuitive user interface which features a thumbnail view of scanned documents and a wide variety of image processing capabilities.
Panasonic KV-S1065C-U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 2540 mm
Input Type
Optical Resolution
600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits)
31.7 cm x 20.9 cm x 19.6 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 2540 mm
Scanner
Input Type
Optical Resolution
600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Scanner Speed Details
60 ppm - black & white - A4 - 200 dpi , 120 ipm - duplex - black & white - A4 - 200 dpi , 60 ppm - colour - A4 - 200 dpi , 120 ipm - duplex - colour - A4 - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, Multi Color Dropout, Image Emphasis, Gamma Correction, Automatic Separation, Noise Reduction, Mirror Image, Dynamic Threshold, Error Diffusion, Dog-Ear Detection, White Level from Paper, auto brightness
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 2540 mm
Plain paper
Automatic
75 sheets
USB 2.0 - Type B
Control sheet
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
25 Watt (8 Watt)
Software Included
Drivers & Utilities, Image Capture Plus
31.7 cm
20.9 cm
19.6 cm
4 kg
15 °C
30 °C
20 - 80%
Scroll to top
