BT.com
Wishlist
Panasonic KV S1046C A4 Desktop Workgroup Scanner
Panasonic KV S1046C A4 Desktop...
£464.53
Hurry, only 3 left in stock!
£464.53
Add to wishlist
Delivery
Standard 1-3 working days
This scanner can quickly convert a large number of documents into electronic data, so it provides smooth usage even in offices with many users. Scanning documents into data makes it possible to consolidate information, which improves work efficiency. And it lowers the cost of handling documents and reduces the space needed to store them.
Double-sided scanning of documents from business-card size all the way to A4 can be done with a single scan. Plus, double-sided scanning is done at the same speed as single-sided scanning. This eliminates the need to repeatedly turn the document over to the front and back to rescan, and prevents pages from being missed when scanning.
The active double-feed prevention roller reverses rotation the instant that the leading document leaves the paper feed section to prevent the double-feeding of documents that are stuck together.
What's in the box
  • Panasonic KV S1046C
  • USB cable
  • Drivers & Utilities, Image Capture Plus
Panasonic KV-S1046C - document scanner - desktop - USB
Document scanner - desktop
Interface Type
USB
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 297 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
45 ppm (mono) / 45 ppm (colour)
Max Document Size
216 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card
Document Feeder Type
Automatic
Document Storage Capacity
75 sheets
Duty Cycle
2000 scans per day
Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits)
31.7 cm x 20.9 cm x 19.6 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Interface Type
USB
216 x 297 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
45 ppm
Max Document Scan Speed Colour
45 ppm
Duty Cycle
2000 scans per day
Scanner Speed Details
45 ppm - portrait B&W - A4 / Letter - 200 dpi , 90 ipm - duplex - portrait B&W - A4 / Letter - 200 dpi , 45 ppm - portrait colour - A4 / Letter - 200 dpi , 90 ipm - duplex - portrait colour - A4 / Letter - 200 dpi
Scanner Features
Ultrasonic Double Feed Detection, double feed prevention roller system, Multi Color Dropout, Double Exposure, Image Emphasis, Gamma Correction, Automatic Separation, Noise Reduction, Mirror Image, Automatic Image Orientation, Long Paper Mode, Dynamic Threshold, Blank Page Removal, Error Diffusion, Patch Code Detection, Separation Sheet Detection, Automatic Binary / Color Distinction, Mixed Document Feeding, Dither, MultiStream Technology, Auto Crop, Auto Deskew, Remove Punch Hole, Dog-Ear Detection, Smooth Background, White Level from Paper, Detect Control
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 2540 mm
Automatic
75 sheets
1 x USB cable
ISO 7810
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
25 Watt (8 Watt)
Software Included
31.7 cm
20.9 cm
19.6 cm
4 kg
Limited warranty - 3 years
15 °C
30 °C
20 - 80%
Scroll to top
