BT.com
Wishlist
Panasonic KV-S1015C Document Scanner
Panasonic KV-S1015C Document...
£240.63
Hurry, only 2 left in stock!
£240.63
Add to wishlist
Delivery
Standard 1-3 working days
The KV-S1015C is a scanner designed for the small or home office, or alternatively a desktop set-up in the business market. The scanner is very compact, yet professional and delivers high quality images up to 600 dpi. It also features Cloud services giving a high level of 'workgroup' productivity and a scanning speed of 20 pages per minute; making it one of the faster compact scanners in the industry.
Many smaller businesses have delayed investing in paperless office projects, however the KV-S1015C will enable businesses to afford a scanner and facilitate the scanning of incoming post, invoices, and payroll and purchasing receipts in order to automate the administration processes, reduce business costs, secure the billing process and ultimately improve business productivity.
Panasonic KV-S1015C-U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 2540 mm
Input Type
Optical Resolution
600 dpi
Max Document Scan Speed
20 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 7, Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Windows 8 (32/64 bits)
30.3 cm x 17.7 cm x 13.7 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 2540 mm
Scanner
Input Type
Optical Resolution
600 dpi
Automatic Duplexing
Scan Element Type
Max Document Scan Speed B/W
20 ppm
Max Document Scan Speed Colour
20 ppm
Scanner Speed Details
20 ppm - portrait B&W - A4 - 200 dpi , 40 ipm - duplex - portrait B&W - A4 - 200 dpi , 20 ppm - portrait colour - A4 - 200 dpi , 40 ipm - duplex - portrait colour - A4 - 200 dpi
Scanner Features
Double Exposure, Gamma Correction, Automatic Separation, Noise Reduction, Shadow Removal, Mirror Image, Dynamic Threshold, Blank Page Removal, automatic colour detection, Smooth Background
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 2540 mm
Plain paper
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
17 Watt (4.5 Watt)
Software Included
Drivers & Utilities, Image Capture Plus, Presto! BizCard 6, Presto! PageManager 9
30.3 cm
17.7 cm
13.7 cm
2.7 kg
10 °C
35 °C
20 - 80%
Other bundles
£240.63
Keep your electronic devices protected
£260.62
Scroll to top
