BT.com
Wishlist
Panasonic Hitachi 4800 Lumens WUXGA Resolution 3LCD Technology Projector
Panasonic Hitachi 4800 Lumens WUXGA...
£1,260.00
27 in stock
£1,260.00
Add to wishlist
Delivery
Standard 1-3 working days
The projector offers a maintenance-free operational life of 7,000 hours when set to eco mode, significantly reducing the Total Cost of Ownership for businesses and educational institutions.
All six models allow both portable and ceiling-mounting, while vertical lens shift and screen adjustment functionality means easy adjustment of images projected onto flat or curved surfaces, as well as angled projection.
Panasonic PT-VZ570AJ LCD projector
LCD projector - High Definition 1080p
Built-in Devices
Speaker
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Lens Shift Direction
Vertical
Bulb type
UHM 270 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
Speakers
Speaker(s) - integrated
38.9 cm x 33.2 cm x 12.5 cm
4.9 kg
LCD projector - HD 1080p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4500 ANSI lumens
Contrast Ratio
5000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.1 - 1.8:1
Uniformity
85 %
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
2,304,000 pixels (1920 x 1200) x 3
Max Sync Rate (V x H)
100 Hz x 91 kHz
Bulb type
UHM 270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Deep Color, Split Screen, PJlink, AMX Device Discovery, Direct Power Off, Crestron e-Control, Colourboard Mode, Dynamic Mode, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6-2.12
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-25 / +25
Horizontal Keystone Correction
-30 / +30
Vertical
Vertical Lens Shift
44%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel - 4 cm
1 x HDMI input - 19 pin HDMI Type A , 1 x composite / component video / RGB input - 15 pin D-Sub (DB-15) , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
2 x AAA batteries, wireless remote control, cable holder
1 x VGA cable
Security Features
Password protection, security bar
Power Source
AC
Nominal Voltage
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software
38.9 cm
33.2 cm
12.5 cm
4.9 kg
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
Scroll to top
