BT.com
Wishlist
Panasonic HC-V10 Black Camcorder Kit inc 8Gb Class 6 SD Card
Delivery
Standard Due date unavailable
A Compact Entry HD Camcorder HC-V10 with an Easy-to-Use Dynamic 70x Zoom and HD Recording.
Compact camcorder HC-V10 features a powerful 63x optical zoom lens with an Enhanced Optical 70x Zoom function that uses the effective area of the sensor to further extend their zooming power at the wide-angle setting. This allows the user to capture beautiful images of sweeping landscapes and pull in distant subjects for truly dynamic close-ups, without the image degradation that occurs with a digital zoom. POWER O.I.S. (Optical Image Stabilizer) produces clear, blur-free images even with handheld 70x zooming.
The HC-V10 offers high definition recording and 70x dynamic zoom in a compact body. HD video can be recorded in the MP4 format, which offers broad compatibility and high compression that results in small files that are easy to share. The HC-V10 also includes the option to record in the iFrame format, which is designed to speed up video editing. With iFrame, the video in your camera is the same format you'll edit, so it's fast to import and edit with compatible video editing applications.
The HC-V10 is equipped with a high-quality optical hand-shake compensation function essential for compact, lightweight body. The POWER O.I.S. suppresses hand-shake without degrading the image quality. The user enjoys clear, blur-free images even with Enhanced Optical 70x zooming. The O.I.S. also features an Active mode to assure clear, beautiful images across the entire range from wide-angle to telephoto without any image degradation because it is an optical system.
The 31.6mm wide-angle* on the V10 Series fits more people and more of the background into the frame than conventional models. Ideal for shooting in small spaces or for capturing a subject together with the backbround. * 35mm camera equivalent.
The iA function automatically selects the most suitable shooting mode at the press of a button. The iA function consists of four functions: POWER O.I.S. (Optical Image Stabilizer), Intelligent Scene Selector, Face Detection and Intelligent Contrast Control.
Panasonic HC-V10 - camcorder - storage: flash card
Camcorder - 720p - widescreen
Media Type
Flash card
Memory Card Slot
SD card
Sensor Resolution
1.5 MP
Effective Sensor Resolution
Video: 0.56 MP - Photo: 0.56 MP
Lens System
Zoom lens - 63x zoom - 1.5 - 94.5 mm - f/1.9-5.7
Focus Adjustment
Automatic, manual
Digital Zoom
100x
Image Stabiliser
Optical (POWER O.I.S. with Active Mode)
Display
LCD display - 2.7"
Supported Battery
1 x Li-ion rechargeable battery - 895 mAh (included)
Composite video/audio, HDMI, USB 2.0
5.5 cm x 11 cm x 6.5 cm
212 g
Camcorder - 720p
Enclosure Colour
Camcorder Sensor Resolution
1.5 MP
Effective Video Resolution
0.56 MP
Effective Photo Resolution
0.56 MP
Widescreen Video Capture
Camcorder Media Type
Flash card
Optical Sensor Type
BSI MOS
Optical Sensor Size
1/5.8"
Optical Zoom
63x
Digital Zoom
100x
Image Stabiliser
Face Detection
Print Standard
Exif Print support
Auto Focus
TTL contrast detection
Face Detection
Face Detection AF/AE
Digital Video Format
H.264, iFrame
Image Recording Format
JPEG
Exposure & White Balance
Min Illumination
1 lux
Exposure Modes
Programme, automatic
Shooting Programs
Spotlight, portrait mode, night portrait, scenery, fireworks, low light, night scene, sports mode, sunset, beach, snow, soft skin
White Balance
Custom, automatic, presets
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1/25 sec
Lens System
Focal Length Equivalent to 35mm Camera
31.6 - 2262mm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Motorised drive
Built-in lens shield
Additional Features
Low Lux / Night Mode
Additional Features
Built-in speaker, Intelligent Scene Selector, takes photos while film recording, Intelligent Contrast Control, Pre-Rec function, Auto Ground-Directional Standby (AGS), face detection, Intelligent Auto (iA)
Display
2.7" LCD display
Resolution
230,400 pixels
Display Form Factor
Rotating
Microphone
Microphone Operation Mode
Stereo
Connector Type
HDMI output , USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities, Panasonic HD Writer HE 1.0
Carrying case, power adapter, USB cable, A/V cable
Details
Battery Life Details
Video recording - 1.4 hours (HD resolution)
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Included Memory Card
8 GB SDHC
Image Storage
JPEG 1920 x 1080 , JPEG 640 x 480
Video Capture
H.264 - 1280 x 720 - 50 fps - 15Mbps , H.264 - 640 x 480 - 50 fps - 6Mbps , iFrame - 960 x 540 - 25 fps - 28Mbps
5.5 cm
11 cm
6.5 cm
212 g
Scroll to top
