BT.com
Wishlist
Panasonic DDR3L 4 GB SO-DIMM 204-pin 1600 MHz / PC3L-12800
Delivery
Standard Due date unavailable
4GB RAM Module (PC3L-12800: DDR3) for Panasonic Toughbook
Compatible with CF-31mk5, CF-53mk4 and CF-54mk1
Panasonic - DDR3L - 4 GB - SO-DIMM 204-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3L-12800)
Low Voltage, unbuffered
Voltage
1.35 V
Panasonic CF-WMBA1404G
Toughbook CF-53
4 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Speed
Non-ECC
Voltage
1.35 V
Panasonic Toughbook CF-53
Scroll to top
