BT.com
Wishlist
Panasonic 5500 Lumens XGA 3LCD Meeting Room Projector
Panasonic 5500 Lumens XGA 3LCD...
£971.29
£971.29
Add to wishlist
Delivery
Standard Due date unavailable
The PT-VZ570 offers a blend of high image quality, low Total Cost of Ownership, flexible installation and collaborative functionality.The projector offers a maintenance-free operational life of 7,000 hours when set to eco mode, significantly reducing the Total Cost of Ownership for businesses and educational institutions. The PT-VZ570 allows both portable and ceiling-mounting, while Vertical Lens Shift and Screen Adjustment functionality means easy adjustment of images projected onto flat or curved surfaces, as well as angled projection.
Panasonic PT-VX600AJ LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Brightness
5000 lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
4:3
Lens
Zoom lens
Lens Shift Direction
Vertical
Bulb type
270 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 7000 hour(s) (economic mode)
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
Speakers
Speaker(s) - integrated
362 Watt
38.9 cm x 33.2 cm x 12.5 cm
4.8 kg
LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
5000 lumens
Contrast Ratio
10000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.2 - 1.9:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
4:3
Video Bandwidth
162 MHz
Display Format
786,432 pixels (1,024 x 768) x 3
Max Sync Rate (V x H)
100 Hz x 91 kHz
Bulb type
270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (vertical)
3LCD Technology, PJlink, Dynamic Mode, Eco Mode
Lens
Zoom lens
Focus Type
Manual
Lens Aperture
F/1.6-1.9
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-35 / +35
Horizontal Keystone Correction
-35 / +35
Vertical
Vertical Lens Shift
40%
Video Input
TV System
Analogue video Signal
Video Interfaces
HDMI, component video, composite video, RGB
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel - 4 cm
2 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in / microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
2 x AAA batteries, wireless remote control
Power Source
AC
Nominal Voltage
362 Watt
Power Consumption Stand by
8 Watt
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software
38.9 cm
33.2 cm
12.5 cm
4.8 kg
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
Scroll to top
