BT.com
Wishlist
Panasonic 4000 Lumens WXGA Resolution 3LCD Technolog Projector
Panasonic 4000 Lumens WXGA...
£1,046.66
£1,046.66
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
Panasonic PT-VW355NAJ - 3LCD projector - WiDi / 802.11a/b/g/n wireless / Miracast Wi-Fi Display
3LCD projector
Built-in Devices
Speaker
Brightness
4000 lumens
Contrast Ratio
12000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
240 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), Intel Wireless Display (WiDi) / IEEE 802.11a/b/g/n wireless / Miracast Wi-Fi Display
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/24p, 1080/60i, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 1080/30p, 1080/25p, 750/50p, 750/60p, 1125/60i, 1125/60p, 1125/50i, 1125/24p, 1125/25p, 1125/30p, 1125/50p, 1080/24sF, 1125/24sF
Speakers
Speaker(s) - integrated
320 Watt
35.2 cm x 27.94 cm x 9.8 cm
3.4 kg
3LCD projector
Built-in Devices
Speaker
802.11a/b/g/n, Ethernet
Projector
Brightness
4000 lumens
Contrast Ratio
12000:1
Image Size
76 cm - 762 cm
Throw Ratio
1.18 - 1.9:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
1,024,000 pixels
Max Sync Rate (V x H)
100 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
IRIS (Intelligent Room Illumination Sensor), Blackboard Mode, Auto Input Search, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, 3LCD Technology, Auto Vertical Keystone, Deep Color, PJlink, AMX Device Discovery, Direct Power Off, Colourboard Mode, Dynamic Mode, Real-Time Keystone Correction, Crestron Connected, USB Viewer, USB Display, Eco Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6-1.9
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
WiDi, Miracast, Wi-Fi
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel - 4 cm
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
2 x AAA batteries, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
Power Source
AC
Nominal Voltage
320 Watt
Power Consumption Stand by
14 Watt
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software, Wireless Manager Mobile Edition 6.3
35.2 cm
27.94 cm
9.8 cm
3.4 kg
20 - 80% (non-condensing)
Sound Emission
37 dB
29 dB
Scroll to top
