BT.com
Wishlist
Panasonic 4000 ANSI Lumens XGA Projector
Delivery
Standard Due date unavailable
The PT-FX400 projector can project data wirelessly from an iPad, iPhone or iPod Touch, as well as offering enhanced brightness, an extended lamp replacement cycle, easy maintenance and reliability. The PT-FX400 has 4,000 lumens of brightness, XGA (1024 x 768 pixels) function.
The series' dust-resistant design keeps the air inside the projector clean for long periods of time and minimizes brightness degradation, while the eco filter's impressive replacement cycle reduces maintenance time. The eco management function also reduces power consumption.
Panasonic PT-FX400EA - 3LCD projector - LAN
3LCD projector
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
4000 lumens
Contrast Ratio
600:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens Shift Direction
Horizontal, vertical
Bulb type
UHM 250 Watt
Bulb life cycle
Up to 6000 hour(s)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Speakers
Speaker(s) - integrated
330 Watt
43 cm x 32.3 cm x 12.6 cm
6 kg
3LCD projector
Built-in Devices
Speaker
Ethernet
Projector
Brightness
4000 lumens
Contrast Ratio
600:1
Image Size
84 cm - 762 cm
Throw Ratio
1.48 - 2.96:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Video Bandwidth
162 MHz
Display Format
2,359,296 pixels (1024 x 768)
Max Sync Rate (V x H)
85.1 Hz x 91.1 kHz
Bulb type
UHM 250 Watt
Bulb life cycle
Up to 6000 hour(s)
Eco-Mode technology, Closed Caption, High-bandwidth Digital Content Protection System (HDCP), Daylight View Technology, Detail Clarity Processor 3, 3LCD Technology, PJlink
Lens
Focus Type
Manual
Lens Aperture
F/1.7-2.6
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Vertical Lens Shift
50% / 50%
Horizontal Lens Shift
27% / 27%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-I input - 24+5 pin combined DVI , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Wireless remote control
Nominal Voltage
330 Watt
Power Consumption Operational (Standby)
9 Watt
Software Included
Wireless Manager Mobile Edition 5.5, Multi Projector Monitoring & Control Software 2.5, Logo Transfer Software
43 cm
32.3 cm
12.6 cm
6 kg
20 - 80% (non-condensing)
Sound Emission
33 dB
29 dB
Scroll to top
