BT.com
Wishlist
Panasonic 2500 Lumens WXGA LCD Short Throw Projector 4.7kg
Free delivery
Delivery
Standard Due date unavailable
Projecting images onto a large screen in a limited space; making lectures go smoothly by eliminating glare of the projection light and the shadow on the screen. The short-throw interactive projectors meet these needs, creating new styles of lectures, workshops, meetings and presentations.
Panasonic PT-TW230EA LCD projector
LCD projector - High Definition 720p
Built-in Devices
Speaker
Ethernet, Fast Ethernet
Brightness
2500 lumens
Contrast Ratio
500:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
UHM 230 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 480i, 525i, 525p, 625p, 625i, 576i, 576p, 1080/60i, 720/60p, 1080/50i, 720/50p, 750/50p, 750/60p, 1125/60i, 1125/50i
Speakers
Speaker(s) - integrated
310 Watt
35 cm x 38.2 cm x 14.3 cm
4.7 kg
LCD projector - HD 720p
Built-in Devices
Speaker
Ethernet
Projector
Brightness
2500 lumens
Contrast Ratio
500:1
Image Size
152 cm - 279 cm
Throw Ratio
0.50:1
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Video Bandwidth
162 MHz
Display Format
3,072,000 pixels (1280 x 800) x 3
Colour Support
Max Sync Rate (V x H)
100 Hz x 100 kHz
Bulb type
UHM 230 Watt
Bulb life cycle
High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, Short Throw Technology, PJlink, 16:10 aspect ratio support, Direct Power Off
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 PIN DIN , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C input - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15)
Wireless remote control
1 x VGA cable - 1.8 m
Nominal Voltage
310 Watt
Power Consumption Operational (Standby)
0.42 Watt
Software Included
Logo Transfer Software, Multi Projector Monitoring & Control Software
35 cm
38.2 cm
14.3 cm
4.7 kg
35 °C
20 - 80% (non-condensing)
Sound Emission
36 dB
29 dB
Scroll to top
