BT.com
Wishlist
Packard Bell Viseo 243D 24" Full HD LED Monitor with DVI & VGA - Black
Delivery
Standard Due date unavailable
Experience the game the way it was meant to be played with a 24" Packard bell full HD (PC system needs to support full HD resolution) Monitor. This monitor is currently the number one bestselling Dabs.com monitor and as John stated in his review it is the "Best bargain of the century" and at only £89.98 you can see why!!!
The easy-to-use Viseo 3 is just right for you and your budget. Choose from tiltable and wall-mountable screens that adapt to your everyday environment. Available in a range of sizes, the Viseo 3 Series features a distraction-free matte screen, paired with your choice of resolution and inputs. Intelligent, eco-aware construction makes these displays our most environmentally friendly.
Smart design
The Viseo 3 Series delivers contemporary style and everyday ease of use. Position a Viseo 3 on your desk using its 30° tilt, from -5° to 25°, to set it at just the right angle for your comfort. Family members can adjust the screen for their perfect sightlines, too. Models with VESA compatibility make wall mounting simple, opening your room to even more opportunity. The front onscreen display button, conveniently placed at the bottom of the bezel, gives you quick control over panel performance, and you have a range of connectivity options. Accommodating your digital lifestyle, select models even include an integrated smartphone holder.
Stunning colour
Available in a range of screen sizes, plus resolutions up to 1920 x 1080, the Viseo 3 Series delivers what you desire. Colours stay true across the screen thanks to wide viewing angles. Blacks are black and whites white with the exceptional contrast ratio of 100,000,000:1, revealing detail once hidden in shadow. Even action scenes are crisp and blur free with a response time as fast as 5ms, making the experience more immersive. Matte screens keep the visuals clear of reflections from your room lighting and background thanks to a diffusing polariser layer that lets you see all the colours without distracting glare
All green
The Viseo 3 Series gives you a screen experience that lets you enjoy all your entertainment and tasks--and be good to the earth at the same time. EcoDisplay technologies employed in the production and use of the Viseo 3 save on materials, energy and expense. Take your environmentalism a step further with models using post-consumer recycled plastics (PCR ABS). Designed to save power, Viseo 3 Series monitors qualify with the new ENERGY STAR® 6.0 guidelines, making them among the world's most efficient displays.
Packard Bell Viseo 243D - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
56.7 cm x 20.68 cm x 42.22 cm
3.9 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV GS, ISO 9241-307
1 year warranty
Display Type
Diagonal Size
24"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
LED backlight
72% NTSC colour gamut
3.9 kg
VGA , DVI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
20.9 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption Sleep
0.45 Watt
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Bargain of the century
Reviewed by Anonymous on 19/03/2014
Fantastic monitor for the price, nothing comes close for the size. Can't fault the image quality or colour with what I use it for.
Complaints about a poorly constructed stand is a bit of an overreaction. Yes it does have some movement if you shake it, but on my desk there is absolutely no issue with it. To put it in perspective, I also have one of the new slim iMac 27" which has almost an equal amount of 'wobble' when you give it a nudge.
5* really happy
Reviewed by John McDonald on 27/12/2013
best bargain of the century. cannot fault this monitor, well boxed and delivered on time for christmas
amazing picture quality and not to big. perfect for gaming at 1080p
4* Not back in black
Reviewed by Anonymous on 18/03/2014
After my 21"CRT died, I finally bought this monitor after weeks of deciding what to buy.
The colours are great, even the white is bright even during day light.
The monitor can wobble due to the stand, but not a problem if keyboard etc are elsewhere.
A bit of black tape over the monitor "on" light is handy.
But, blacks on the screen are all washed out/greyish & no amount of fiddling with the monitors settings or Catalyst haven`t really helped get me a decent black on screen.
Only really a problem if like me you`re into gfx &/or dark spooky games.
Size is very good & at this price, I`m very impressed.
1* Packard Bell Viseo 243D 24" Full HD LED Monitor
Reviewed by Sarwar Jahan on 27/02/2014
Built Quality is very poor.The base is made with low quality plastic. very shaky.Returned it
Scroll to top
