BT.com
Wishlist
Optoma W304M WXGA DLP 3100 Lumens Projector
Optoma W304M WXGA DLP 3100 Lumens...
£729.16
15 in stock
£729.16
Add to wishlist
Delivery
Standard 1-3 working days
Ideally partnered with a widescreen notebook, HD sources or a mobile device, the W304M delivers bright vivid presentations and videos in the office or on the road.
This travel-friendly projector incorporates a staggering 3100 ANSI lumens allowing you to project bright, crystal clear presentations during the day, leaving your audience speechless every time the projector is turned on.
Being small doesn't mean that you miss out on specification though, the W304M incorporates a built in speaker, HDMI connectivity, Full 3D technology and wireless capabilities allowing you to project wirelessly from a laptop or mobile device. It also comes with a convenient carry bag for easy transportation.
Projecting with laptops, Macs or even tablets has never been so easy.
Optoma W304M - DLP projector - portable - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3100 ANSI lumens
Contrast Ratio
10000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
SHP 220 Watt
Bulb life cycle
Up to 4000 hour(s) / up to 5000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i
Speakers
Speaker(s) - integrated
280 Watt
22 cm x 17.8 cm x 7.1 cm
1.5 kg
2 years warranty
DLP projector - HD 720p
3D Capable
Built-in Devices
Speaker
Enclosure Colour
Projector
Brightness
3100 ANSI lumens
Contrast Ratio
10000:1
Image Size
79 cm - 943 cm
Projection Distance
1.2 m - 12 m
Uniformity
80 %
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 91.4 kHz
Bulb type
SHP 220 Watt
Bulb life cycle
Controls & Adjustments
Mute, input select, keystone correction
LED Indicators, DLP Link
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x composite video input - RCA , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), keypad lock
Nominal Voltage
280 Watt
Power Consumption Stand by
0.5 Watt
22 cm
17.8 cm
7.1 cm
1.5 kg
Limited warranty - 2 years , Limited warranty - lamp - 1 year
5 °C
45 °C
0 - 85%
32 dB
Scroll to top
