BT.com
Wishlist
Optoma S303 SVGA DLP HDMI 3000 Lumens Projector
Delivery
Standard Due date unavailable
Ideal for use in a meeting room or classroom, the S303 has a bright 3000 L and 15,000:1 contrast allowing you to project bright, crystal clear images with superb colors using DLP and BrilliantColor technologies. Incredible lamp life combined with Eco+ technology provides energy and money saving features.
Optoma S303 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
15000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
226 Watt
31.6 cm x 22.4 cm x 12.4 cm
2.21 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
15000:1
Image Size
69 cm - 762 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.97 - 2.17:1
Uniformity
85 %
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
BrilliantColor, DLP 3D Ready, DarkChip3 single-chip DLP technology, AMX Device Discovery, Auto Power Off, Eco+ technology, ProJect Green
Lens
Lens Aperture
F/2.51-2.69
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - mini-phone 3.5 mm , 1 x USB , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Carrying case, wireless remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
Nominal Voltage
226 Watt
Power Consumption Stand by
0.5 Watt
31.6 cm
22.4 cm
12.4 cm
2.21 kg
5 °C
0 - 85%
26 dB
Scroll to top
