BT.com
Wishlist
Optoma ML1500e WXGA 1280 x 800 HDMI VGA Portable 3D Projector
Delivery
Standard Due date unavailable
Insert the SD card straight from your phone or camera to instantly share memories with small or large groups, without the need for extra cables. Alternatively leave a slideshow with audio running in the background before kicking off a meeting, to whet your audiences' appetite and stimulate discussion. Sit back after a long day to enjoy your favorite movies... without the need for file conversion; the ML1500 directly supports all the most popular video and music file formats and being both HD-Ready and LED, you can also be sure of vibrant colors, depth and clarity that will not disappoint.
Optoma ML1500e DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Brightness
1500 lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
Composite video (NTSC, PAL, M-NTSC)
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080i, 480i, 576p
Speakers
Speaker(s) - integrated
145 Watt
27 cm x 17 cm x 4.8 cm
1.4 kg
2 years warranty
DLP projector - HD 720p
3D Capable
Projector
Brightness
1500 lumens
Contrast Ratio
20000:1
Image Size
43 cm - 254 cm
Projection Distance
0.52 m - 3 m
Throw Ratio
1.4:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 49.64 kHz
Bulb type
LED
Bulb life cycle
Up to 20000 hour(s)
OSD Languages
Brazilian Portuguese, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish
BrilliantColor, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, ProJect Green, SRS WOW HD technology
Lens
Lens Aperture
F/1.5
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, PAL, M-NTSC
Analogue video Signal
Composite video
Video Interfaces
VGA, HDMI, composite video
Video Modes
SD Memory Card
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
3 Watt
Expansion Slots
1 x SD Memory Card
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x USB - 5 pin Micro-USB Type B
Carrying case, remote control
1 x HDMI cable
Security Features
RoHS
Power Source
AC
Nominal Voltage
145 Watt
Power Consumption Stand by
0.5 Watt
27 cm
17 cm
4.8 cm
1.4 kg
5 °C
35 °C
0 - 85%
30 dB
Scroll to top
