Click to visit BT.com
BT.com
Wishlist
Optoma EX784 XGA 1024X768
Quicklinx: 82FJWS00
Mfr#: EX784
Exceptional brightness, excellent connectivity and amazing colours ensure the Optoma EX784 XGA projector is the perfect choice for any large venue or conference room.
The environmentally friendly EX784 has energy saving features including < 0.5 W standby mode and auto power off saving you both time and money. Our unique Optoma Colour guarantee ensures hassle-free, long-lasting projection.
RS232 CONTROL The extensive RS232 command set makes it simple and easy to control the EX784 with any control system.
Crestron RoomView® - NETWORK CONTROL
RoomView® software provides a custom configurable interface to monitor, manage and control every device in every room remotely from any computer.
o Manage up to 250 projectors at the same time (via master PC)
o Control and alter the projector settings using a simple web browser page including OSD menu control
o Set up email alerts for warning messages
o Ideal for large installations in both the educational and business environments
EXTENSIVE CONNECTIVITY
This native XGA projector accepts a wide variety of computer and video input signals.Connectivity includes: HDMI, DVI-D, dual VGA (SCART/ Component via adaptor), S-Video, Composite, VGA-Out, RS232 , RJ45 and +12V trigger.
Two audio inputs for individual PC and video connections enablethe EX784 to function as an audio switcher and volume controller,thereby eliminating complicated and costly additional audio hardwareand cabling.
Clear, Focused Images
DarkChip3™ technology from Texas Instruments produces a stunning 3000:1 contrast ratio for pin sharp graphics and crystal clear text. Crisper whites, ultra-rich blacks makes images come alive and text easier to read - ideal for business and education presentations.
VIRTUALLY MAINTENANCE FREE = LOWER COST OF OWNERSHIP
EX784 provides lower cost of ownership, longer life and improved reliability. The filter-free projector design does not require regular filter cleaning or filter replacement, saving you time and money.
3D Technology
Using the inherent speed of DLP technology, The Optoma EX784 can output video and images at an astonishing rate of 120Hz, allowing you to show full screen, full colour, stereoscopic 3D. The 3D effect is generated by splitting this signal into two standard video streams, one for each eye. Using DLP® Link™ technology, the 3D glasses synchronise with the image on screen to filter each stream to the correct eye. Your brain then combines the two streams to make them jump into life. The 3D features of Optoma projectors can only be used with compatible 3D content. Typical applications include use with 3D educational or 3D design and modelling systems. Support for 3D TV broadcast systems, (SKY in the UK) or Blu-ray 3D™ will require the Optoma 3D-XL that is available separately. See website for updates.
EXTRA FEATURES
o Easy lamp replacement from the top cover
o Direct power on - start up time is significantly reduced as standby mode is bypassed when the power cable is inserted into an active power outlet. This eliminates the need to use the Power button on the remote control or the projector keypad.
o Signal power on - the projector will power on when it receives a signal. This eliminates the need to use the `Power' button on the remote control or the projector keypad.
o Auto power off - if after a pre-determined time the projector does not receive a signal, it will turn itself off automatically, conserving power and extending the life of the lamp.
o Key pad lock - once enabled prevents unauthorised adjustments ensuring the projector can only be controlled via the remote control.
o +12v Trigger - electric screen control
o Logo capture - customise your start up screen
o Easy to use remote with laser pointer, mouse control and direct source selection
Optoma EX784 DLP projector - 3D
DLP projector
3D Capable
Microdisplay
DarkChip 3
Brightness
5000 lumens
Contrast Ratio
3000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb life cycle
Up to 2000 hour(s) / up to 3000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video ( PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC )
Digital Video Standard
Digital Visual Interface (DVI), High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Video Output
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V ( 50/60 Hz )
370 Watt
32.6 cm x 25.9 cm x 10.9 cm
3.5 kg
5 years warranty
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
5000 lumens
Contrast Ratio
3000:1
Image Size
71 cm - 834 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.8 - 2.11:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91 kHz
Bulb life cycle
Controls & Adjustments
Keystone correction
sRGB colour profile, BrilliantColor, Crestron RoomView, AMX Device Discovery, DLP Link
Lens
Lens Aperture
F/2.6-2.81
Zoom Type
Manual
Zoom Factor
1.15x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, DVI
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Input Device
External
Movement Detection Technology
Infrared
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 ( management ) , 1 x composite video input - RCA , 1 x S-video input - 4 PIN mini-DIN , 1 x audio line-in - RCA x 2 , 1 x component video / RGB / SCART - 15 pin HD D-Sub (HD-15) , 1 x DVI-D input - 24 pin digital DVI , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x network - RJ-45 ( management ) , 1 x HDMI input - 19 pin HDMI Type A
Carrying case, lens cover, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS
Nominal Voltage
370 Watt
Power Consumption Operational ( Standby )
1 Watt
32.6 cm
25.9 cm
10.9 cm
3.5 kg
5 years warranty
Service & Support Details
Limited warranty - 5 years
5 °C
Sound Emission
30 dB
28 dB
