BT.com
Wishlist
Optoma EX555 - DLP projector - 3D - 3000 ANSI lumens - 1024 x 768
Delivery
Standard Due date unavailable
Mobile, Eco+ Green Projection
3000L - Project in ambient light
XGA resolution, 13,000:1 contrast ratio
Up to 6500h increased lamp life + 70% energy saving
Lightweight and portable, carry bag included
The Optoma EX555 is the perfect projector for all your display needs. An ultra-bright 3000L with a 13,000:1 contrast, ensures your presentations and graphics are crystal clear leaving your audience speechless every time the projector is turned on. Ideal for use with interactive whiteboards in schools or delivering an important presentation at work.
Installed or on the move, the versatile EX555 incorporates a built in speaker, 120Hz 3D Ready technology and Eco+ technology that brings together superb picture quality and performance with optimized lamp life through energy saving features that are easy to use.
DLP projector
3D Capable
Built-in Devices
Speaker
Microdisplay
DMD Chip
Brightness
3000 lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) / up to 6500 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
200 Watt
28.8 cm x 22 cm x 8.4 cm
2.2 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DMD Chip
Brightness
3000 lumens
Contrast Ratio
13000:1
Image Size
70 cm - 770 cm
Projection Distance
1.2 m - 12 m
Throw Ratio
1.95 - 2.15:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
BrilliantColor, 16:9 aspect ratio support, 3D-XL Ready, Eco+ technology
Lens
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x USB - 4 pin USB Type B , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm
Carrying case, remote control
1 x VGA cable
Mounting Kit
Optional
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
Nominal Voltage
200 Watt
Power Consumption Operational (Standby)
0.5 Watt
28.8 cm
22 cm
8.4 cm
2.2 kg
5 °C
0 - 85%
Sound Emission
30 dB
28 dB
Resources
The following resources are available for the Optoma EX555 - DLP projector - 3D - 3000 ANSI lumens - 1024 x 768
  • Documentation
Scroll to top
