Click to visit BT.com
BT.com
Wishlist
Optoma ES550 - DLP Projector - 3D Ready - 2800 ANSI lumens - SVGA (800 x 600) - 4:3
Quicklinx: 7VPQWS00
Mfr#: Es550
You can project even if there is ambient light in the room. The SVGA resolution ES550 delivers an impressive 2800 L, ensuring that even during the day everyone can clearly see the projected image. Reduce the number of lamp changes with lamp life of up to 6000 hours. The lamp is conveniently located so that it can be changed without removing the projector from a ceiling mount - saving you time and money.
High contrast ratio, 5000:1 for a crystal clear viewing experience. Ensure you have your audience's attention during a presentation with crisp whites and ultra-rich blacks making text and graphs easier to read. Bring images and video alive on the big screen for a fantastic viewing experience.
DLP Projector
Brightness
2800 ANSI lumens
Contrast Ratio
5000:1
Portability
Portable
Resolution
800 x 600
Audio Output / Type
Speaker(s)
Dimensions & Weight / Depth
23 cm
Dimensions & Weight / Height
7.7 cm
Dimensions & Weight / Width
28 cm
Display / Max Image Size
762 cm
Display / Max Screen Distance
12 m
Display / Min Image Size
69 cm
Display / Min Screen Distance
1.2 m
Header / Product Line
Optoma
Projector Lamp / Bulb life cycle
5000 hour(s)
Video Input / Analogue Video Format
SECAM
Video Input / Analogue video Signal
S-Video
2.2 kg
