BT.com
Wishlist
Optoma EH1020 DLP HD Projector 3000 ANSI Lumens
Delivery
Standard Due date unavailable
The native 1080p EH1020 DLP projector unleashes the power of your presentation to engage your audience with stunning graphics, high-resolution images and razor-sharp presentations. Lightweight and bright at 3000 ANSI lumens, the EH1020 is loaded with a wide range of convenient connectivity options, including HDMI. The EH1020 transcends the ordinary to deliver extraordinary projection performance.
Optoma EH1020 - DLP projector
DLP projector - High Definition 1080p
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2200:1
Resolution
Full HD (1920 x 1080)
Bulb type
230 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 4000 ns (economic mode)
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p
Speakers
Speaker(s) - integrated
281 Watt
32.4 cm x 23.4 cm x 9.7 cm
1 year warranty
DLP projector - HD 1080p
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
2200:1
Image Size
92 cm - 921 cm
Projection Distance
1.5 m - 10 m
Throw Ratio
1.5:1 - 1.8:1
Uniformity
85 %
Resolution
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
230 Watt
Bulb life cycle
Lens
Lens Aperture
F/2.55-2.87
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-20 / +20
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
8 Watt
Input Device
External
1 x USB - 4 pin USB Type B , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x video cable , 1 x USB cable
Security Features
Nominal Voltage
281 Watt
Power Consumption Operational (Standby)
1 Watt
32.4 cm
23.4 cm
9.7 cm
Limited warranty - 1 year , Limited warranty - lamp - 3 months
5 °C
0 - 80%
Sound Emission
31 dB
Accessories
£118.77
Scroll to top
