BT.com
Wishlist
Opticon OPN 2006 Barcode Scanner
£166.14
38 in stock
£166.14
Add to wishlist
Delivery
Standard 1-3 working days
The OPN-2006, part of the OPN-2000 series is a Bluetooth companion scanner. Remarkable features of this device are its outstanding specifications which include the use of Bluetooth 3.0, a high-performance 1D scan engine and low power consumption during operation.
Opticon OPN 2006 - barcode scanner
Barcode scanner - portable - USB, Bluetooth 3.0 - decoded
Minimum Bar Width
5 mil
Scan Field Width
6 cm - 30 mm
Scan Element Type
2D imager
Scan Speed
100 scan / sec
Wireless, wired
Wireless Connectivity
Bluetooth
Lithium Ion
3.2 cm x 1.6 cm x 6.2 cm
29 g
Barcode
Interface Type
USB, Bluetooth 3.0
Minimum Bar Width
5 mil
Scan Field Width
6 cm - 30 mm
Scan Element Type
2D imager
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Skew (Degrees)
80
Pitch (Degrees)
50
Print Contrast Signal (PCS)
45%
Decode Capability
EAN/JAN, Code 93, Matrix 2 of 5, Industrial 2 of 5, Code 39, NW-7, IATA, ISBN, GS1 DataBar, Telepen, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, PDF417, MSI-Plessey, China Post, Korea Post, Trioptic Code, ISSN, UK-Plessey, S-Code
TTL Decoding
Decoded
Wireless, wired
OK Notification
LED indicator, vibration
Real-time clock
Bluetooth
RAM
96 KB
Flash
512 KB
1 x mini-USB
Neck strap
1 x USB cable - external
VCCI, FCC, RoHS, FDA, JIS C 6802 Class 2, IEC 60825-1 Class 2
Lithium Ion
3.2 cm
1.6 cm
6.2 cm
29 g
20 - 85% (non-condensing)
Drop Specification
1.5 m to concrete
Scroll to top
