BT.com
Wishlist
OmniMount Wall Mount 20-40"
£29.59
2 in stock
£29.59
Add to wishlist
Delivery
Standard 3-5 working days
The NewStar LED TV wall mount, model LED-W120, allows you to mount a LED TV to any wall. Cause of the flexible hole pattern of this system is this wall mount useable for almost every LED TV up to 40 inches. This wall mount is easily to install by using the VESA hole pattern at the rear side of your TV. This wall mount can be used when the maximum distance between the holes (left to right) is 20 cm. The upper and lower holes allow a maximum distance of 20 cm. This LED TV wall mount is made of aluminum and is mountable to any wall.
NewStar LED-W120 - wall mount
Wall mount
Adjustable Depth
1.5-3 cm
Recommended Use
LCD display
Recommended Display Size
22"-40"
Flat Panel Mount Interface
Up to 200 x 200 mm, from 100 x 100 mm
Max Load Weight
50 kg
5 years warranty
Adjustable Depth
1.5-3 cm
AV Furniture
Wall mount
Mounting Components
Wall mount
Recommended Use
TV
100 x 100 mm, 200 x 200 mm, 200 x 100 mm
22"-40"
Max Load Weight
50 kg
Fixed
Limited warranty - 5 years
Scroll to top
