BT.com
Wishlist
Olympus VG-170 Smart Digital camera - 3D - 14.0 Mpix - 5x Optical Zoom - Red
Delivery
Standard Due date unavailable
Experience a compact and convenient point-and-shoot camera - but with a truly brilliant extra: Besides being absolutely easy to handle, the new VG-170 provides a flash nearly twice as powerful as on a regular compact camera. The Guide Number is approx. 8.8, in contrast to 4 to 5.6 with comparable cameras. Thanks to the long flash mode you can even light up faces and objects up to fully 15 meters away, as it automatically selects higher ISO sensitivity. 14 Megapixels and a 5x wide optical zoom (26-130mm*) enable effortless close-ups and wide-angle shots. In addition to the big 3" LCD, 720p HD Movie with sound and lots of automatic features and effects, be sure to get a high quality photo or movie every time. With its slim, stylish body and sturdy retro design, the VG-170 could be mistaken for a high-end camera - until you learn about the fantastic low-budget price!
Box Contents
LI-50B Lithium-Ion Battery
F-2AC AC Adapter
CB-USB7 USB Cable
CB-AVC5 Audio/Video cable
3D Glasses (Red/Cyan)
Hand Strap
World Wide Warranty Card
Instruction Manual
[ib] Image Management Software
Olympus VG-170 - digital camera
Digital camera - 720p - compact
Sensor Resolution
14.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 5x zoom - 4.7 - 23.5 mm - f/2.8-6.5
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Digital Zoom
4x
Image Stabiliser
Electronic
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 925 mAh (included)
Composite video/audio, USB 2.0
Red
10.4 cm x 2.2 cm x 6.3 cm
147 g
Enclosure Colour
Red
Sensor Resolution
14.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
14,500,000 pixels
Effective Sensor Resolution
14,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
1600
Optical Zoom
5x
Digital Zoom
4x
Image Stabiliser
Electronic
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO auto
Exposure Metering
Multi-segment
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, beach/snow, self-portrait, PET, fireworks, 3D image, night scene, sports mode, sunset, indoor, cuisine, candle, night scene with portrait, anti shake, documents
Special Effects
Fisheye, soft focus, Water Colour, Drawing, Pop Art, pin hole, Punk, Reflection
Retouch
Beauty Retouch Mode
White Balance
Custom, automatic, presets
White Balance Presets
Tungsten light, daylight, overcast, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
26 - 130mm
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
5 groups / 7 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
AF illuminator, long flash mode
Effective Flash Range
8.8 m: ISO 800 , 15 m: ISO 1600
Additional Features
Continuous Shooting Speed
2 frames per second, 0.6 frames per second, 15 frames per second for 20 frames (3MP)
Self-Timer Delay
2sec, 12sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, digital noise reduction, date/time stamp, cropping an image, in-camera panorama preview, resizing an image, Scene Detection Technology, Face Detection AF/AE, in-camera red-eye fix, Automatic Pixel Mapping (APM), USB charging, built-in help guide, Shadow Adjustment Technology, Advanced Face Detection Technology, Shade Correction, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, distortion control
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output
Software
Software
Drivers & Utilities, [ib] software
Hand strap, power adapter, USB cable, A/V cable, 3D glasses
Battery Type
Olympus Li-50B
Details
Memory / Storage
RAM Installed
34.9 MB
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4288 x 3216 , JPEG 3264 x 2448 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 1600 x 1200 , JPEG 1280 x 960 , JPEG 640 x 480 , JPEG 1920 x 1080
Video Capture
AVI - 1280 x 720 - 30 fps , AVI - 1280 x 720 - 15 fps , AVI - 640 x 480 - 30 fps , AVI - 640 x 480 - 15 fps , AVI - 320 x 240 - 30 fps , AVI - 320 x 240 - 15 fps
10.4 cm
2.2 cm
6.3 cm
147 g
Scroll to top
