BT.com
Wishlist
Olympus TG-870 Tough Camera Green 16MP Wifi
Delivery
Standard Due date unavailable
The TG-870 is a Tough camera capable of capturing active scenes in the great outdoors. Its optical 5x zoom lens starting from an ultra-wide 21mm makes it easy to capture vast landscapes, and a 180° flip-up monitor helps shooting in narrow spots. It is also equipped with more Art Filters than the previous model, making it more enjoyable and convenient to use.
Olympus Stylus Tough TG-870 - digital camera
Digital camera - 1080p - compact
Memory Card Slot
SD card
Image Processor
TruePic VII
Wireless Interface
Wi-Fi
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 5x zoom - 3.74 - 18.7 mm - f/3.5-5.7
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Digital Zoom
4x
Image Stabiliser
Optical (HYBRID O.I.S.)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Olympus Li-50B Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Green
11.29 cm x 2.76 cm x 6.41 cm
221 g
Enclosure Colour
Green
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
16,800,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
5x
Digital Zoom
4x
Image Processor
TruePic VII
Image Stabiliser
Face Detection
Navigation
GPS receiver
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face-priority AF function
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
Composite video/audio, HDMI, USB 2.0, Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view, Wi-Fi & OI.Share
Exposure & White Balance
Light Sensitivity
ISO 800, ISO 125, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Multi-segment, spot
Exposure Modes
Programme, automatic
Special Effects
Vivid, fisheye, soft focus, natural, Muted, Water Colour, Diorama, Cross Process, Grainy Film, Light Tone, Pop Art, Pale & Light Colour, pin hole, Gentle Sepia, Dramatic Tone, Sparkle, Reflection, Fragmented, Key Line, Vintage
White Balance
Custom, automatic, presets
White Balance Presets
Incandescent, fluorescent, cloudy, sunlight, Underwater
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
21 - 105mm
Focus Adjustment
Automatic
Min Focus Distance
10 cm
Macro Focus Range
1cm
Zoom Adjustment
Motorised drive
Lens Construction
8 groups / 10 elements
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
AF illuminator, wireless off-camera control
Effective Flash Range
0.12 m - 4 m: ISO 1600 (wide lens) , 0.1 m - 2.5 m: ISO 1600 (tele lens)
Additional Features
Continuous Shooting Speed
2.5 frames per second, 60 frames per second (3MP), 20 frames per second (3MP), 7 frames per second for 7 frames
Self Timer Delay
2sec, 12sec
Additional Features
Audio recording, built-in speaker, cropping an image, resizing an image, in-camera red-eye fix, interval shooting mode, in-camera film editing, USB charging, Shadow Adjustment Technology, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Smart Panorama, Time-Lapse recording
Tripod Mount
Connection Point
Display
3" LCD display
Resolution
920,000 pixels
Display Form Factor
Folding
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , Composite video/audio output , HDMI output (19 pin micro HDMI Type D)
AC power adaptor, USB cable, wrist strap
Protection
Waterproof, crushproof, freezeproof, shockproof, dust resistant
Underwater Depth
Up to 15 m
Battery Type
Olympus Li-50B
Details
Battery Life Details
Photo shooting - 300 shots , Video recording - 1.5 hours
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Video Capture
H.264 - 1920 x 1080 p - 60 fps , H.264 - 1280 x 720 p - 60 fps , H.264 - 640 x 480 p - 60 fps , H.264 - 640 x 480 - 120 fps , H.264 - 854 x 480 - 120 fps , H.264 - 480 x 360 - 240 fps , H.264 - 640 x 360 - 240 fps
11.29 cm
2.76 cm
6.41 cm
221 g
-10 °C
Scroll to top
