BT.com
Wishlist
Olympus TG-620 Tough Digital Camera - Blue
Delivery
Standard Due date unavailable
On coral reefs, rock faces or adventure playgrounds, image quality has often been the second priority. Whether busy parent or adrenalin junky, most people are just happy if their camera gets home in one piece. But for new TOUGH owners it's different. They can have both: outstanding image quality from a camera with a worry-free guarantee. Of course, as the first-ever manufacturer to deliver super-tough compacts, Olympus has ensured the T-620 is no less robust then their predecessors. What is different is iHS. This combination of advanced components means even people with an action-packed lifestyle can capture photos and Full HD movies to be proud of, no matter how fast their subject is moving nor how poor the light. With its high sensitivity and low noise capability, iHS powers a number of Olympus features that take all the work out of capturing difficult shots. Like a blazing quick autofocus and HDR backlight adjustment that takes a collage of separate photos and blends them into one perfectly exposed image when you're shooting against the light. Or multi-motion movie IS that lets you record virtually blur-free movies even when you're moving yourself. The precision 5x wide optical zoom lens offers the flexibility to pull out wide or zoom in close for amazing action close-ups. The TG-620 is waterproof to 5m, shockproof from 1.5m and will likewise survive a night on the piste at -10°C.
Olympus Tough TG-620 - digital camera
Digital camera - compact
Memory Card Slot
SD card
Image Processor
TruePic VI
Internal Storage
46.8 MB
Sensor Resolution
12.0 Megapixel
Max Video Resolution
1920 x 1080
Lens System
5 x zoom lens - 5 - 25 mm - f/3.9-5.9
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Digital Zoom
4 x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Built-in flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery ( included )
Interfaces Provided
USB 2.0
Blue
9.8 cm x 2.2 cm x 6.6 cm
167 g
Built-in Light
LED lights
Enclosure Colour
Blue
Sensor Resolution
12.0 Megapixel
Optical Sensor Type
BSI-CMOS
Total Pixels
12,700,000 pixels
Effective Sensor Resolution
12,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
6400
Optical Zoom
5 x
Digital Zoom
4 x
Image Processor
TruePic VI
Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Pet Detection
Digital Video Format
QuickTime, MJPEG
Image Recording Format
JPEG, MPO
1920 x 1080
Interfaces Provided
USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto
Exposure Metering
Multi-segment, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, beach/snow, self-portrait, fireworks, 3D image, panorama assist, night scene, sports mode, sunset, indoor, cuisine, candle, beauty, night scene with portrait, documents, underwater snapshot, dog, cat, backlight correction HDR
Special Effects
Fisheye, soft focus, Water Colour, miniature, Drawing, Pop Art, pin hole, Punk, dramatic, Reflection, Fragmented
White Balance
Automatic, presets
White Balance Presets
Fluorescent, sunlight, tungsten light, overcast, Underwater
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
28 - 140mm
Focus Adjustment
Automatic
Min Focus Distance
60 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
8 groups / 11 elements
Built-in lens shield, ED glass, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
Effective Flash Range
0.2 m - 3.5 m : ISO 800 ( wide lens ) , 0.5 m - 2.5 m : ISO 800 ( tele lens )
Additional Features
Continuous Shooting Speed
5 frames per second, 15 frames per second (3MP), 60 frames per second (3MP)
Self Timer Delay
2sec, 12sec
Additional Features
Audio recording, RGB primary colour filter, digital noise reduction, date/time stamp, digital image rotation, camera orientation detection, histogram display, cropping an image, resizing an image, saturation control, in-camera red-eye fix, USB charging, dual image stabilization, Shadow Adjustment Technology, Advanced Face Detection Technology, Backlight Correction HDR, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, distortion control, Multi-motion Movie Image Stabilisation (IS), Intelligent High Speed (iHS) technology
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x HDMI output , 1 x composite video/audio output
Software
Software
Drivers & Utilities, [ib] software
Hand strap, AC power adaptor, USB cable, A/V cable
Body Material
Metal
Protection
Waterproof, freezeproof, shockproof
Underwater Depth
Up to 5m
Battery Type
Olympus Li-50B
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Internal Storage
46.8 MB
Image Storage
JPEG 3968 x 2976 , JPEG 3264 x 2448 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 1600 x 1200 , JPEG 640 x 480 , JPEG 3968 x 2232 , JPEG 1920 x 1080
9.8 cm
2.2 cm
6.6 cm
167 g
-10 °C
Scroll to top
