BT.com
Wishlist
Olympus Stylus Traveller SZ-15 - 16.0 Mpix - 24 x optical zoom - black
Delivery
Standard Due date unavailable
Zoom performance, new perspective
24x super wide optical zoom
16 Megapixel CCD
Tele-Photo Macro
A compact as cute as the SZ-15 really has no right to a 24x super wide optical zoom lens. Most cameras of this size just can't find room for that sort of magnifying power, let alone the flexibility to shoot in 16-Megapixel quality at super-wide angles. And they certainly don't have space for Super-resolution Zoom, which doubles still photo magnification to 48x with none of the pixilation that usually makes digital zooms so ineffective. One of the reasons to get a camera with this sort of magnifying capability is to capture macros with those eye-popping colours and details that mostly go unseen. But macro shooting isn't always easy. If you get too close, the camera casts a shadow. Or you startle tiny creatures and before you get the shot. That's why the SZ-15 has Telephoto Macro. This clever feature lets you shoot macros up to 40cm from your subject - with all the power of a 600mm telephoto (35mm equivalent). And in case you're worried about blur, don't be. Dual Image Stabilisation takes care of that. For getting creative on-camera, the SZ-15 gives you 11 Magic Filters. Plus a great canvas: HD movies or stills captured close-up. And blur-free.
Get phenomenal close-ups with the 24x optical zoom and 48x with Super Resolution.
Compact and lightweight, the 24x optical zoom has an impressive focal length range of 25-600mm, giving you superb flexibility. With super resolution zoom you can double zooming power to 48x and get exceptionally close to far-away subjects without any remarkable loss of image quality.
16-Megapixel CCD Sensor for High Quality - Produce top-grade stills, movies & prints.
Engineered to produce an image resolution of 16 Megapixels so you can reproduce your stills in large, high-quality formats and use digital zoom to crop photos to the perfect size
HD Movies AVI Motion JPEG - Maximise the frame-by-frame quality of your filmmaking.
Dual Image Stabilisation combines Sensor-Shift Image Stabilisation with high ISO sensitivity and fast shutter speeds, so you can capture crisp, clear images, even if the subject is moving
Get close up, even far away - Shoot tiny subjects at a distance with telephoto macro shooting.
Complementing the ultra-powerful 24x zoom, the SZ-15 lens lets you zoom in on detail and get as close as 40 cm to your subject without disturbing it - for amazing, blur-free macro shots.
Magic Filters for Stills and Movies - Create works of art in an instant with your SZ-15.
Add style to stills and movies with Punk, Pop Art, Pin Hole, Fish Eye, Soft Focus, Sparkle (photos only), Watercolour, Reflection, and Miniature. New filters: Fragmented (photos only) creates a collage of tiles, as if the original photo had been cut up and reassembled; and Dramatic boosts the contrast to give images a more dynamic atmosphere
TRUEPIC PROCESSOR
This powerful image processor forms a part of the in-built iHS technologies dedicated to high overall image quality. Not only does it offer image processing capabilities with high resolution while maintaining high-level colour reproduction. It also provides improved colour controllability in specific colours such as emerald green and yellow. The image processing speed are also increased, along with startup and shooting speeds
EYE-FI COMPATIBILITY
An Eye-Fi card enables you to automatically upload images using WiFi. Being compatible with your camera, you can activate and deactivate this card as you wish directly in your setting menu. Whenever the need or moment arises, you can then share photos and movies on your camera directly with other devices. You can transfer them to your mobile device and then share them with friends and family through your social networks
3? DISPLAY
Olympus 3? Displays are the first choice for easy framing, reviewing and sharing of photos and movies. The imaging power of these monitors is characterised by vivid colour reproduction and high levels of contrast with improved resolution up to 1.030k dots and great new technologies like OLED for even further improved viewing and framing possibilities
FACE DETECTION TECHNOLOGY
A technology that searches for faces in a composition and recognizes them as the main subject. It then automatically puts them in focus and optimally adjusts exposure to create an image that's sharp in the right places and ideally exposed. Available for photos and videos, Advanced Face Detection Technology can detect up to 8 faces
AF TRACKING
This system tracks a moving subject automatically and keeps it continuously in focus for optimally exposed pictures. It even memorizes the subject when it goes out of frame and resumes tracking when it reappears
DUAL IMAGE STABILISATION
Providing two-fold protection, this special function helps to avoid image blur caused by camera shake. It combines high ISO values with a sensor- or lens based mechanical image stabiliser, where a built-in sensor detects camera movement and adjusts the image sensor or lens accordingly
ULTRA-WIDE OPTICAL ZOOM LENSES
Compact and portable, yet extremely powerful, Olympus zooms in up to 40x for extremely dramatic close-ups and backs out for sweeping wide-angle panoramas. Wide-angle lenses from 24mm to 28mm combine incredible tele-zoom performances of up to 896mm without any digital zoom effects
Olympus Stylus Traveller SZ-15 - digital camera
Digital camera - 720p - compact
Memory Card Slot
SD card
Image Processor
TruePic III+
Sensor Resolution
16.0 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 24x zoom - 4.5 - 108 mm - f/3.0-6.9
Focus Adjustment
Automatic
Min Focus Distance
20 cm
Digital Zoom
4 x
Image Stabiliser
Optical (image sensor shift mechanism)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
1 x Li-ion rechargeable battery - 925 mAh (included)
Interfaces Provided
USB 2.0
10.73 cm x 3.98 cm x 6.88 cm
220 g
Enclosure Colour
Sensor Resolution
16.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
16,500,000 pixels
Effective Sensor Resolution
16,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
1600
Optical Zoom
24 x
Digital Zoom
4 x
Image Processor
TruePic III+
Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Advanced Face Detection technology, face-priority AF function
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
Interfaces Provided
USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO auto
Exposure Metering
Multi-segment, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, beach/snow, self-portrait, PET, fireworks, panorama assist, night scene, sports mode, sunset, indoor, cuisine, candle, beauty, night scene with portrait, documents, telephoto macro
Special Effects
Fisheye, soft focus, Water Colour, miniature, Pop Art, pin hole, Punk, Sparkle, dramatic, Reflection, Fragmented
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, sunlight, tungsten light, overcast
Max Shutter Speed
1/2000 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
25 - 600mm
Focus Adjustment
Automatic
Min Focus Distance
20 cm
Macro Focus Range
3cm
Zoom Adjustment
Motorised drive
Lens Construction
10 groups / 11 elements
Built-in lens shield, ED glass, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
AF illuminator
Effective Flash Range
0.2 m - 6.9 m: ISO 800 (wide lens) , 0.4 m - 3 m: ISO 800 (tele lens)
Additional Features
Continuous Shooting Speed
0.45 frames per second, 15 frames per second for 20 frames (3MP), 1.5 frames per second (3MP)
Self Timer Delay
2sec, 12sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, digital noise reduction, date/time stamp, digital image rotation, camera orientation detection, histogram display, in-camera red-eye removal, cropping an image, resizing an image, saturation control, USB charging, built-in help guide, dual image stabilization, Shadow Adjustment Technology, Shade Correction, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, distortion control
Display
3" LCD display
Resolution
460,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
1 x USB 2.0 , 1 x composite video/audio output , 1 x HDMI output
Software
Software
Drivers & Utilities, [ib] software
Hand strap, AC power adaptor, USB cable
Body Material
Metal
Battery Type
Olympus Li-50B
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Video Capture
MJPEG - 1280 x 720 - 30 fps - SDHC Class 6 recommended , MJPEG - 640 x 480 - 30 fps
10.73 cm
3.98 cm
6.88 cm
220 g
Scroll to top
