BT.com
Wishlist
Olympus SP-810UZ Traveller Digital Camera - 3D - 14.0 Mpix - 36x Optical Zoom - Black
Delivery
Standard Due date unavailable
You can't get more flexibility than this. When it comes to choosing your subject, the 36x wide-angle zoom on the new SP-810UZ guarantees virtually limitless freedom. No compact camera from Olympus has ever delivered better zoom performance. A fast, wide 1:2.9-5.7 24-864mm zoom lens, and 14 Megapixel image sensor makes the SP-810UZ the benchmark in its class. As the new flagship in the Olympus' Traveller category, it's the successor to the prestige SP-800UZ. Not only is the SP-810UZ better equipped than its predecessor, it's also more compact. As the smallest compact camera currently on the market with a zoom factor over 30, the SP-810UZ is the ideal travelling companion.
Olympus SP-810UZ - digital camera
Digital camera - compact
Enclosure Colour
Sensor Resolution
14.0 Megapixel
Optical Sensor Type
CCD
Total Pixels
14,500,000 pixels
Effective Sensor Resolution
14,000,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
36x
Digital Zoom
4x
Image Processor
TruePic III+
Image Stabiliser
Optical (image sensor shift mechanism)
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support, PRINT Image Matching
Auto Focus
TTL contrast detection
AE/AF Control
Subject-tracking AF
Digital Video Format
MPEG-4
Image Recording Format
JPEG
Max Video Resolution
1280 x 720
Composite video/audio, HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, portrait mode, beach/snow, self-portrait, fireworks, night scene, sports mode, sunset, indoor, cuisine, candle, beauty, night scene with portrait, documents, dog, cat
Special Effects
Fisheye, soft focus, Water Colour, miniature, Drawing, Pop Art, pin hole, Punk, Sparkle, Reflection
Retouch
Beauty Retouch Mode
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, sunlight, tungsten light, overcast
Max Shutter Speed
1/850 sec
Min Shutter Speed
4 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Zoom lens - 36x zoom - 4.3 - 154.8 mm - f/2.9-5.7
Focal Length Equivalent to 35mm Camera
24 - 864mm
Focus Adjustment
Automatic, manual
Min Focus Distance
30 cm
Macro Focus Range
5cm
Zoom Adjustment
Motorised drive
Lens Construction
14 groups / 16 elements
ED glass, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, auto mode, flash OFF mode, red-eye reduction
AF illuminator
Effective Flash Range
0.5 m - 6.2 m
Additional Features
Continuous Shooting Speed
0.73 frames per second, 30 frames per second for 60 frames (2MP), 18.2 frames per second for 36 frames (3MP)
Self Timer Delay
2sec, 12sec
Additional Features
Audio recording, built-in speaker, RGB primary colour filter, digital noise reduction, date/time stamp, digital image rotation, camera orientation detection, histogram display, cropping an image, resizing an image, saturation control, Face Detection AF/AE, Automatic Pixel Mapping (APM), USB charging, dual image stabilization, Shadow Adjustment Technology, In-Camera Manual, Advanced Face Detection Technology, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Pet Detection, distortion control
Display
3" LCD display
Resolution
230,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output , HDMI output
Software
Software
Drivers & Utilities, [ib] software
Lens cap, hand strap, power adapter, USB cable, audio / video cable
Battery Type
Olympus Li-50B
Details
1 x Li-ion rechargeable battery - 925 mAh (included)
Memory / Storage
RAM Installed
14 MB
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
JPEG 4288 x 3216 , JPEG 3264 x 2448 , JPEG 2560 x 1920 , JPEG 2048 x 1536 , JPEG 1600 x 1200 , JPEG 1280 x 960 , JPEG 640 x 480 , JPEG 4288 x 2416 , JPEG 1920 x 1080
Video Capture
MPEG-4 - 1280 x 720 , MPEG-4 - 640 x 480 , MPEG-4 - 320 x 240
10.6 cm
7.4 cm
7.6 cm
413 g
Resources
The following resources are available for the Olympus SP-810UZ Traveller Digital Camera - 3D - 14.0 Mpix - 36x Optical Zoom - Black
Scroll to top
